LED test / review
EN
Cree XLamp XP-L HD, XP-L HI, XP-G2, XP-E2, XM-L2
XPLAWT-00-0000-0000V5051
XPLAWT-H0-0000-0000V3051
XPGBWT-L1-0000-00L51
XPEBWT-L1-0000-00G51
XMLBWT-00-0000-0000U4051
In this thread I will present the widely used Cree SC5 based LED emitter line-up (3 V class currently), presented to the public in 2012 to 2014. My goal is to establish a single-post resource for raw data and other important values and measurements of these older LEDs, including the well-known over current diagrams.
If new results are available I'll update this post(s). Luminance results of all emitters shown here will follow soon. Raw data are also available in this post!
XP-L High Density (HD)
Tj 85 °C / If 1,050 mA unless noted otherwise
Order code: XPLAWT-00-0000-0000V5051
Type: single die (lateral)
Binning: V5 (typ. 460 lm)
Rated voltage: typ. 2.95 V (max. 3.25 V)
Forward current: max. 3,000 mA
Viewing angle: typ. 125° (FWHM)
Thermal resistance: typ. 2.2 °C/W
Junction temp.: max 150 °C
The official datasheet can be found here (offficial Cree website, pdf)
XP-L High Intensity (HI)
Order code: XPLAWT-H0-0000-0000V3051
Binning: V3 (typ. 420 lm)
Viewing angle: typ. 115° (FWHM)
XP-G2
Tj 85 °C / If 350 mA unless noted otherwise
Order code: XPGBWT-L1-0000-00L51
Binning: S4 (typ. 164 lm)
Rated voltage: typ. 2.8 V (max. 3.15 V)
Forward current: max. 1,500 mA
Thermal resistance: typ. 4.0 °C/W
currently only diagram of dedomed XP-G2 S4 is shown here. LED tested here is the 'old' version of XP-G2 in highest bin S4, before production process was changed.
XP-E2
Order code: XPEBWT-L1-0000-00G51
Binning: R4 (typ. 130 lm)
Rated voltage: typ. 2.9 V (max. 3.25 V)
Forward current: max. 1,000 mA
Viewing angle: typ. 110° (FWHM)
Thermal resistance: typ. 9.0 °C/W
XM-L2
Tj 85 °C / If 700 mA unless noted otherwise
Order code: XMLBWT-00-0000-0000U4051
Binning: U4 (typ. 340 lm)
Rated voltage: typ. 2.85 V (max. 3.15 V)
Thermal resistance: typ. 2.5 °C/W
at 5,200 mA the test ended due to burnt bonding wires.
Note: this post is WIP.
Changes may occur at all times, so stay tuned and thanks for reading! :)
Greetings, Dominik (aka BLF member koef3)
Mistakes, suggestions or offers / sponsoring of LEDs which I should test next are best sent via PM.
