Malkoff M61L HCRI2 drop in for sale. $65.00 reduced $60.00 shipped to the CONUS.
This drop in has less than 1 minute of total run time on it. Here is your chance to own an old fashioned Incandescent like modern LED drop in for your light host.
The “HCRI2” designation is referring to the LED, that succeeded the original “HCRI” model released a few years ago. It features a Cree XP-G2 which puts out around 2900K at a minimum of 90 CRI. The drop in output is yellowish, and is for incandescent fans!
The “L” designation means “Low” output for situations where you do not need as bright a light but a longer run time.
The input voltage is 3.4 - 9 volts. Below 3.4 volts it will drop out of regulation and run in direct drive. The output is approximately 125 out the front lumens. The current draw is only 280mA at 6 volts. The full output run time is approximately 5 hours on two CR123 primary batteries with a nice long taper as voltage drops. It also runs very well with a single Li Ion 18650, or 2x18500 cells.
As always the BLF rules of sale apply. The first I’ll take it, gets it. Paypal accepted. Thank you for looking.
