It should go back up. It goes back up on my samples. I changed the code so that it increases very slowly, and after the temperature has cooled below the set threshold by some amount to reduce hysteresis.
USPS raised their prices significantly at the beginning of the year. You can check USPS.com for current rates. I don't overcharge on shipping, and if we charge you too much we refund the difference. That has always been the policy.
Finally got around to populating a couple of the new V1.11 17mm drivers. One I did for a psw-te25 firmware/power switch light using the provided kit parts, having a 25 MCU but using a SIR800DP instead, and the other board I built up for Narsil/e-switch usage: larger voltage divider resistor values, Tiny85 MCU, SIR404DP, no OTC.
Both bench tested perfectly, so look'n nice and stable. Love these boards - nice thin look, but better//heavier traces. Can't wait to see them in action.
This board, combined with the Tiny85 and top spec'd SIR404DP FET, can't really get much better.
Richard, can you build a 22mm single-cell driver for the Jaxman host?
I don’t know if that would need more than ‘just’ mounting an existing driver on a bigger diameter board.
There is a new 20mm FET+1, but I guess a 22mm version is easily doable by keeping exactly the same layout and just adding 2mm extra balank space to the pcb.
Yup. once RMM’s driver that works with TK’s firmware settles down, it’ll be 17mm I’m sure.
I’d like to get that mounted onto a 22mm board to fit the Jaxman.
I know y’all can do this stuff yourselves.
I can, sometimes, but — older and with shaky hands — results can get ugly.
Hank, I'm a bit confused. What firmware are you talking about? Bistro? That's been available since February. I don't have a 22mm FET+7135 yet, but you can bet there's one coming.
1. Do you plan on offering the XP-G3 on a 16mm pad?
2. I’m looking at building a Convoy S6 (the reason for question #1) with a smooth reflector. Could you swap the standard OP reflector for the SMO, or should I just order it separately?
