Luminance is based on lumens per area of die size. So if you know that the SST-20 has 30% less lumens and is 50% smaller (for example), then it must have a higher intensity (luminance).
I managed to make my convoy L2 not kill my last sst20 and at 5.1A current I measured 1240 lumens and 233 kcd with stock led and dome on. Next step is to shave the dome and polish it.
That’s assuming equal polar distribution of course.
It’s only that simple if the LEDs are flat with no dome and have a perfect sinusodial distribution.
If they have a dome then it would depend.
I think SST20 is a led that can do this. I have also one which first died in the L2 and after that I shaved the dome and sliced the dome around the die and then lifted itself.
But the die still worked. just the bond wires burned.
So I cranked up the amps and it was blue and smoking for a while and then executed completely.
Any updates? I have killed exactly 14 sst-20s with chemical dedoming attempts, so far no success,BUT I’m getting close tho. prolbem is the bond wires are so darn delicate. I got 3 nice looking dedomes but with broken bond wires. Waiting on 10 more to arrive from china.
Sounds like they are similar to SST 40 with delicate long bond wires. I gas dedomed one SST 40 successfully but killed several others by pulling bond wires. Unfortunately I think slicing is the most reliable way. But you have to slice very close to the die to get max luminance gains. The last SST 40s I did I sliced below the level of the bond wires, but left the silicone section right around the wires. It ended up looking like in this thread . I plan to do this with some SST 20s but haven’t had the time yet.
