Q8, PMS SEND TO THOSE WITH ISSUES BLF soda can light
I need someplace to keep my “spare” 30Qs so another Q8 would be a perfectly sensible option, Right? :wink: I mean, just cause I haven’t received my first one yet is that any reason. :slight_smile:
Pot meet kettle
Those who think they don’t get as much output as expected can also make sure the battery tube is tightly threaded into the head so that it makes better contact with the driver ground ring.
Making sure the tube end is clean and having it tight is something to check on any light that relies this current path - not just the Q8.
But first make sure the bare metal end of the battery tube is clean and flat.
If you have a little ding or flange of metal sticking up, that’s the only surface area that will make contact with the ground ring, and it will gouge the ground ring as it’s tightened.
I had a ding with a raised sharp edge that did that. Cleaned it off by rubbing a piece of hardwood until it smoothed out, didn’t have any fine grain sandpaper handy.
Good buy.
Strong and steady.
https://www.gearbest.com/iphone-mounts-holders/pp_242382.html
This is the only thing I can see in photobosta
I will not pay $ 400 for a photobosta account, there are free places to upload photos
Second unit ordered
Thanks
3rd ordered, colleage promised to order my 4th one on the code.
Yeah, something goes wrong……
Only the Q8, I bought 8x 30Q too, but it shipped in the same day……
I dont tried to reorder because the refund dont came yet :confounded:
Yes, you’re not the only person who won’t.
https://www.google.com/search?q=photobucket+embed+fix
Fix for the Photobucket screw-you change is available for Firefox too
Did you forget to add me to the list? :slight_smile:
1726 preorders right now. That’s almost 99% of the interest list! :+1:
I don’t know how many hours (if any) are left before the GB code expiration.
hey all. i got my Q8 today. thank you, its look and feal good, but i got issue with the driver position. can see it in the picture.
i hope somthing can be done to fix it.
btw, i did not put batteryes inside yet.
You can unscrew the driver and use a 3mm drill to open up the holes for the screws to be the same size as the screws so they don’t thread into the driver, but only in the flashlight body, that will make it sit more level.
The battery marks are normal, every light is tested before it goes out of the factory.
EDIT to put link with picture : Q8 modding - #373 by Etex
(wouldn’t fear warranty issue, no one can see ;-))
i could try it but fear of warranty issue. :innocent:
Yes, and you might see a little bump in output when done
This is very sloppy assembled.
Which warranty?
not sure actualy, i assume there is some warranty if the light dosnt work.
The code isn’t lasting long is it being extended? We had the BLF A6 code lasted for like 6 months.
I want to order mine when it’s ready to ship.
