Currently using a LaCrosse BC900 charger for (re)charging my NiHM cells.
I want to charge/discharge two (or more) cells in the BC900 and using different charge/discharge current for each cell (due to variation in cell sizes and capacities). Is it possible to set different charge/discharge currents for each cell in the BC900 when all cells are "processed" at the same time?
I tried setting a different charge and discharge current for a second cell inserted into the BC900 after the first cell (charge/discharge) current was set at 200 mA / 100 mA, but the BC900 did not seem to allow me to set another current for the second cell? And yes, I selected the slot with the second cell to set the charge mode; charge mode selected OK, but current couldn't be selected or changed for the second cell. It appears that the BC900 will not allow changes to current settings for other cells inserted, and will default to presently selected current for the first cell only? Anyone confirm this?
I've also ordered the OPUS BT-C2000 charger as it allows charging of cells that are nearly 100% depleted (apparently). But I am not certain whether this charger allows selecting different currents for each cell or not? Anyone know?
Thanks.
