Its probably debatable if this head design would effect heat transfer that much seeing as its so high up and there would need to be lots of heat soaking to send heat up that high at least with the output we are getting from this light stock.
I think we would prefer the head to be one piece and a thicker shelf but besides that it all seem good.
Sofirn could you please confirm what size MCPCB you are using?
Why is the finning not where the heat is? This is one of those high power lights in which the heat path is a big deal, and Sofirn has little clue.
You need thick material near the source of the heat (the 6mm shelf and thick tube there is a good start but from there the heat has to pass thin material to faraway fins) spreading the heat quickly out in all possible directions via an as short and thick route as possible, and close to a series of good sized fins, thinning out further down the flashlight for dissipation from additional surface.
The light as it is now will need an unneccessary short stepdown time on turbo and has a lower sustainable level than possible.
In flashlight design there are always compromises that have to be made. If it had ideal heat distribution and fins all around the the shelf area, you would have a really ugly light that would be difficult to hold and people wouldn’t want to buy it. So you have to find a balance.
What do you mean about “it will need an unneccessary short stepdown time on turbo”? You mean 10 seconds sooner? No light this size can cope with 100+ watts of heat for more than a minute or two anyway.
To me it’s like people complaining about a light making 5000 lumen instead of 5100 lumen. It seems so insignificant. It’s not like the shelf is 1mm think and the light has no mass. It looks beefy and I’m sure that at lower brightness levels the heat will eventually spread.
I mostly agree with you (I altered my post a bit because it was a bit harsher than intended), the light will perform just ok, but I just think that in designing a high power flashlight form follows function: you start with best performing design, you notice that it is ugly and heavy and unbalanced, and then you see how much shaving and altering you can get away with without sacrifying too much performance. That way I’m sure you end up with a good looking and balanced flashlight that has better performance than this light that is being designed the other way around.
I support the proposal/suggestion to use Maxtoch direct-thermal-pad MCPCB or any known suppliers of quality direct-thermal-pad MCPCB regardless of size. I hope it won’t be the same supplier of the 30 mm MCPCB that ships with the updated C8F. The quality of the board leaves much to be desired. I can attest by my own experience that this particular MCPCB is not very durable. The solder pads are very prone to breaking. I can only hope they won’t skimp on this one. Just saying.
I agree, seems like a pretty bad design to have the heat transfer a good distance and through the threaded joint before it reaches the fins. I’m wondering is this more suitable for the 3x XHP70.2 setup where the emitter board will be mounted much higher and in contact with the upper head.
The more I look at the threaded head, the less I like it. It looks great on the outside, but that threaded joint is going to do very VERY little for heat transfer. There are zero fins directly connected to the LED shelf; all the heat will have to go through the threads before it even touches a heat fin.
I would pay extra to have a solid, one piece head. If they every decide to use this same design for a 3x XHP70, they would probably have to redesign the entire head (unless they mounted the LED’s up very very high).
User Interface
It reads like the one from the Sofirn SP32A v2
(v2 has a newer quick ramping) I have one and its verry close to NarsilMs ramping, but with one fixed mode set. I like that UI.
Top off the ramp and TURBO
I would suggest to make the top of the ramp 50% output and with a double click you get TURBO with 100%
Keeps the lamp cooler and you lose not too much of light. GTmini does the same. I like this: Ramp up to see if i get enough light on an object and if not, boom, a bit of extra light.
