Ampsplus INR18650 3000mAh (Black)
Official specifications:
Size: 18.33±0.07mm x 64.85±0.15mm
Nominal Voltage: 3.60V
Nominal Capacity: 3000mAh / 0.2C discharge
Charge Metod 100mA cut-off: CC-CV (4.2±0.05V)
Standard charge time: 0.5C / 180min.
Discharge Voltage: 2.50V (Average Cut Off)
Charging Current CC: 1500mA
Rapid Charging Current: 4000mA
Continuous Discharge Current: 15A Max
MVA: 20A
Battery Rate: 5C
Weight: 48.0 gr.max
Colour: Black , Red , SIlver
Protection: No
This is a high current battery with good capacity.
The two cells tracks nicely and the capacity loss is not very large up to 20A.
At 20A the cell get rather hot.
And at 30A I had to stop the discharge due to temperature.
Conclusion
This is a good battery and the rewrap has not changed that.
Notes and links
The batteries was supplied by Ecoluxshop for review.
Compare to 18650 and other batteries
