Efest IMR18650 2500mAh (Purple) 2017
Official specifications:
Rated capacity: 2500mAh
Nominal voltage: 3.7V
Voltage at end of discharging: 2.5V
Max. charging current: 4A
Standard charge: 2A
Discharging current 20A
Pulse discharging current: 35A
Charging temperature range: 0°C ~ 45°C
Discharging temperature range: –20°C ~ 75°C
Inner resistance: 20mOhm
Cell size: 18.50 (±0.20)mm x 65.20 (±0.2)mm
A 2500mAh high current 18650 cell.
The discharge curves looks very good with nearly constant capacity up to 20A.
The cell do get fairly hot at 20A as can be seen I stopped discharge on one of the cells.
At 30A the cells did not get as warm. It is a new battery holder because the old one was damaged (Heat melted something in it).
Conclusion
The batteries looks like a good battery, but compare to the Efest 2600 I wonder why they have this battery (It may be due to price).
Notes and links
The batteries was supplied by Efest for review.
Compare to 18650 and other batteries
