Hohm 18650 Life4 3015mAh (Black-white)
Official specifications:
Capacity: 3015mAh
Max Charge Rate: 4.43A
Max Charge Voltage: 4.2V
Continuous Discharge Rate: 22.1A
Max 80oC | 3.2V cut-off: 31.5A
Pulse | Peak6: 37.1A
Cycle Life Retention: 500 @ 70, 1000 @ 60
Chemistry Type: QSP Li-NMC
This is a fairly high capacity and high current cell.
Oops, the two batteries do not match in capacity, this means never use them in series. One of the cells is significantly below rated capacity.
Conclusion
I am not happy about the difference in capacity between the batteries and the very precise capacity rating do not really match the batteries.
Notes and links
The batteries was supplied by Hohmtech for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
