LiitoKala 26700 4000mAh Lii-40E (Orange)
Official specifications:
Battery Type: Rechargeable Lifepo4
Nominal Capacity: 4000mAh , Real
Nominal Voltage: 3.2v 3.3v
Battery Dimension: 26.5x71mm(±0.02mm)
Battery Weight: About 93g
Internal Resistance: less than 20 mohms
Cycle life: More than 2000 times, DOD at 80%
Input Charging Voltage: 3.65v/cell
Input Charging Current: 2A
Continuous Discharging Current: 3C
Max Current Discharge: 5C
Discharge cut-off Voltage: 2.50v/cell
Charging Temperature: 0°C ~ 45°C
Discharging temperature: –20°C ~ 60°C
Storage temperature: –20°C ~ 45°C
A LiFePO4 in 26650 size with fairly good capacity.
The two cells matches very nicely and can deliver the rated 3C or 12A.
Conclusion
This is a good LiFePO4 battery and as usual for this type it has very stable output voltage and less energy contents than the more common LiIon types, but longer life.
Notes and links
The batteries was supplied by a reader for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
