Uniross Charger LCD 3-5H
This is a fairly simple NiMH charger for AA and AAA cells.
I got the charger in a blister pack. The pack has a few specifications on it.
The pack contained the charger and an instruction sheet.
The charger plugs directly into a mains outlet
The user interface is a LCD display with 4 batteries on it and a 3. different messages: CHARGE, READY, BAD.
Very simple and easy to understand.
Specifications are listed on the back.
The charger uses the typical two level slots for NiMH AA/AAA batteries.
Measurements charger
Power consumption when idle is 0.63 watt
Charge will restart charging after power loss, or battery insertion.
Will discharge NiMH batteries with less than 0.1mA when unpowered.
Nice charging, the termination is slightly slow, but works.
A little bit faster termination this time.
Oops, about two hours to termination.
Again a nice curve.
Also a nice curve.
This cell is very worn and the charger cannot really terminate on it. The time used is exactly the same as \#3 above, it looks like a maximum charge time/capacity. The limit is fairly good for AA cells, it prevents serious over charge.
With AAA a lower charge current is used and again the termination was rather slow.
A full cell is discovered and charging stopped.
Charge speed is the same with 4 cells in the charger.
M1: 29.0°C, M2: 31.6°C, M3: 33.4°C, M4: 31.1°C, HS1: 38.1°C
The charger is fairly low current and do not get very warm.
M1: 30.3°C, HS1: 48.0°C
The charger needs a about 1.4 seconds to initialize.
It has both short and long measuring pulses, I wonder why.
Testing the transformer with 2830 volt and 4242 volt between mains and low volt side, did not show any safety problems.
Conclusion
This is a simple and not that fast charger and sometimes it misses termination, but due to its capacity/time limit it will always stop without doing any serious damage to the batteries.
I will rate it acceptable.
Notes
Charge selection table
