I like the design and I like that it uses 4 18650 batteries. I don’t like that the built in ‘charger’ part of it doesn’t behave properly. Why do almost all of these things have little ‘bugs’ in them? This isn’t exactly rocket science.
The main purpose is to charge attached equipment, especially when you are without access to mains power. The batteries in the box can easily be removed and charged on a real battery charger.
They maybe you misinterpreted his conclusions? It seems to work just fine in delivering up to 2A current output. It’s just when recharging the batteries in the box itself that it has a small issue. The charging circuit seems to sensitive to voltage drops in the batteries and will restart charging them too soon. His recommendation is to disconnect the input cable in a reasonable amount of time, as opposed to leaving it plugged in overnight or longer. This is not a safety issue, but will wear out the batteries faster due to the frequent recharge cycles when already near full capacity.
Please, read again my original post #16 in this thread...
I have no problems charging batteries in the box. The problem is that the box doesn't charge any "attached equipment" (phone) - there is no current/voltage output
That post, is in response to the general idea of these back up phone chargers in that they all have some design fault or another. Not one, or at least not many, are perfectly built. It was not in response to your dud unit.
From my original post #16: "The same thing happens with different amount of batteries, different kind of batteries, different charge level of the batteries, different phones - the box doesn't work!"
The "Charger Doctor" doesn't show current/voltage output
The same batteries work without problems in my ENB box.
And that's why I think I received a "defective unit"
You might need to get a USB charger doctor and see if the output voltage is too high, one of my portable power units I have (the one I built myself) I hook up the charger doctor to it…it says 5.15vdc and it won’t charge my phone (unless I use a specific cord [odd I know]) when charging the voltage sags down to 4.97 and stays there with an approx .47A draw. Funny thing is…it will charge EVERYTHING else except my phone without that one particular cable)
The voltage starts too high and the device being charged won’t start charge because output is too high
All my other chargers start at 5vdc ± .4-.5vdc (so low is sometimes like 4.97vdc, high is 5.05vdc)
As I mentioned one post above yours, "The "Charger Doctor" doesn't show current/voltage output". It's blank. And yes, it's working fine everywhere else I connect it to.
Anyway, I contacted gearbest and look forward to hearing from them
I purchased two of these Huamen/Evertone ET-406 power banks from Gearbest after HKJs review.
They arrived 2 days ago, almost 7 weeks after ordering.
To begin with the end: both are defective, one DOA, one self-destructed on first full charge cycle.
Gearbest ticket opened yesterday, no response so far. Paypal dispute will be filed tomorrow (to meet 45 days deadline).
Together with zebroo’s case in #16 that makes 3 failures.
In detail:
The DOA box doesn’t charge the batteries. Doesn’t signal charging state with the LEDs, and input current is only some 10mA. I measured this with a charger doctor and with professional equipment in an electronics lab (my workplace). On one short occurence there were 1.3A input current (too much, 1.0A is normal) for about a minute, but I wasn’t able to reproduce this.
It also doesn’t deliver output current - that is, it does, but switches off after a few seconds. It also doesn’t signal “output current flowing” with the LEDs. Tested with 0,5A, 1A, 2A output current.
I suspected maybe a bad solder joint, opened it, but couldn’t find anthing looking suspicious.
The second box worked perfectly at first, charging and discharging as tested by HKJ.
In the lab I charged 4 batteries from almost full (4.0V) to full (4.18V), and discharged with 2.1A output current (electronic ballast). No problems. Worked fine, LEDs giving correct signals for charging and discharging.
Back home I started recharging the empty batteries (3.3V) on a 5V wall plug with USB power monitor. The monitor showed 5.05V 0.98A. The wall plug is high quality (no cheap crap).
After about an hour I smelled smoke, and lookin up noticed the power bank’s blue LEDs and the USB monitor’s display going on and off. The box constantly drove the power supply into overcurrent shutdown and restarted. I pulled the plug, opened the lid and removed the batteries. The front part of the box was quite hot. The batteries were okay (not hot, about 3.65V).
I opened the box and found burnt components (2 of the 4 battery switch transistors plus resistors) and brown traces of smoke on the inside of the lower lid. (I have photos if I find a way to post them.)
PS: I used 4x unprotected Samsung ICR18650-32A and LG18650-D1 for testing.
