Vapcell INR18650 2000mAh (Green) 2018
Official specifications:
Model: INR18650 2000mah 28A
Nominal voltage: 3.60V
End-of-charge voltage: 4.20V
End-of-discharge Voltage: 2.5V
Typical Capacity: 2000mAh (0.2C discharge)
Min capacity: 1900mAh (0.2C discharge)
Weight: Max:50g
Internal resistance: Max: 10mOhm (AC 1kHz)
Standard Charge: 2000mA,CCCV 100mA cut-off
Charging Time: 1.5hours(standard charge)
Quick Charge Current: 3000mA
Max Continuous Discharge Current: 28000mA
This battery is fairly low capacity, but very high current.
The discharge curves tracks very well and the cell can deliver the rated 2000mAh at any current up to rated maximum.
Conclusion
This is a good battery for high current applications, but capacity is on the low side.
Notes and links
The batteries was supplied by Vapcell for review.
Compare to 18650 and other batteries
