Vapcell INR21700 4500mAh G45 (Purple) 2020
Official specifications:
Model: INR21700 4500mah 20A
Nominal voltage: 3.60V
End-of-charge voltage: 4.20V
End-of-discharge Voltage: 2.5V
Typical Capacity: 4500mAh (0.2C discharge)
Min capacity: 4400mAh (0.2C discharge)
Weight: Max: 70g
Internal resistance: Max:16mOhm AC 1kHz
Standard Charge: 1500mA,CCCV 100mA cut-off
Quick Charge Current: 3000mA
Max Continuous Discharge Current: 20A
This is a fairly high capacity 21700 LiIon cell with good current capabilities.
The two cells match nicely, they cell can just about handle 15A continuous, but they get rather hot at that current.
Conclusion
The battery is not a top capacity rating, but in praxis the difference is not very large, especially when you need more than minimum voltage.
The battery looks good as long as the load is keep below 15A
Notes and links
The batteries was supplied by Vapcell for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
