Vapcell S4 Plus can only fit 2x 26650s on the outer bays (bay 1 & bay 4).
Some chargers that can fit 4x 26650:
Liitokala Lii-600
SkyRC MC3000 (can fit 2x 32650 on the 2 outside bays)
Xtar VP4 Dragon (can fit 4x 32650 or 4x āDā-size batteries) = this is the widest 4-bay charger Iāve seen yet.
In post # 45 Tatasol Confirms it can take 4 X 21700? Is this true? HKJ sent.me pictures disputing this.Maybe that was version 1?
I can deal without 4 X 26650.If it can not do 4 X 21700 this is a No go.
It is shame my version 2 of Folomov A4 had 2 failures due to Display completely malfunctioning.That version 2 could accommodate 4 X 26650 and 4 X 21700.
I do not think there is a charger that exists can do the following: Especially be able to be purchased in USA.
Accomodate 4 X 26650 and 4 X 21700.
Must be able to do at Least 4 X 2Amp in each slot and preferably 2 X 3A in 1 and 4 slots.
Be able to see ALL info in 4 slots at once.
The only one I know is Folimov A4 and its version 2 has Too many issues primarily the Display Completely failing in Two.of them in less than 6 months.
I think the Mi boxer can do it but can not be bought in USA and is shipped from China by Amazonā¦no thanks.
EDIT- The SkyRc MC3000 may be able to do that. Itās way too expensive and I donāt need another analyzer. Not sure if you can read all four displays at once. Even so, I wouldnāt want it for $100. I want a simple charger like the Folomov A4ā¦but it has to be relaible and not fail like 2 of the 4 I got.
Final conclusionā¦there is not one that will meet my requirements other than A4 which I will not get again because of issues already mentioned.
Not sure why HKJ sent me 2 pics. One showing it can only hold 2 X 26650 and the other showing 2 x 18650 and 2 x 21700.Assuming it could not hold 4ā¦because that was my question?
Only thing I can think of is that is version 1.
The dealer opens up in 20 minutes! Seems like I got my answers before they can tell me!
Just got it.It can charge 3 X 26650 which is good enough.That is how many I charge after using my NI40ā¦EACH cell lasts about 15 min.I bring a total of 3 including the one in the light.
The only negative I see so far is that stupid buzzer when the batteries are done. 100% and a battery icon when the grid is solid is enough for me. Especially in the summertime when I charge them while Iām sleeping. Or letās say try to sleep. I am of millions of Americans who donāt sleep much 4 to 5 hours a night thatās it. I donāt need that stupid buzzer waking me up. I guess that means no charging overnight.
Now I am waiting for members to sayā¦Do not charge unattended! I am attending in a state of meditation !
My only other gripe that was not listed in previous posts is that it wont revive an over discharged NiMH. I really like using this for AA Eneloops since it has the 1A charge rate and better termination than my Miboxer (for NiMH) which seems to stop early.
This charger has always had very high potential but seemingly everyoneās use finds a pretty big con with it despite the nice amount of overall features.
I think alot of notice imperfections or defectsā¦I know I do.Here is another one.
Especially when there are three or four batteries itās difficult to get them out. I probably had 10 different Chargers in my life. Only Fenix gets it right as far as removing the batteries. They have an indent at the positive end where our index finger fits and easily gets the batteries out.
Fenix ARE-C2 is the only charger that I have that has used this technology so to speak.
For this S4 Plus I have used my fingernail and I donāt want to ruin the wrapper, or a little piece of wood, popsicle stick at the positive end to get it loose and then pulled out. I guess another way is at the negative and where the spring is to pull back on that. I havenāt tried that yet.
Has anybody opened this one ? Buzzer is a big no no for me, if itās easy to open (i.e. not welded like many plastic cases like this) then itās not really a problem to remove the buzzer.
Or you could lay a piece of ribbon between the batteries and case so you have a little pull/lift tab. Iāve not done it but it would be similar to what is included with many multi cell electronics.
I understand the concept. But how is that supposed to work if you have 4 batteries in there and one piece of ribbon when you pull on it you might disturb the other ones. So Iām not going to cut a little piece of ribbon for each one!
I will manage like I do with the other ones. Itās just a pain in the you-know-what.
After using PD18w charging for powerbanks etc or QC3.1 charging itās totally sucks when the specs of most 4 slot chargers are 4x 500mA. It just takes too long, I want at least 2A per slot preferably 3A. I donāt want to wait 3 or 4 hours to charge an 18650 itās just not necessary with todayās tech. I have a Nitecore USM4 which is decent buy could be better, components are low grade, voltage readouts are not accurate. I want to upgrade but havenāt found the perfect charger yet.
Thatās okay. Like I said in my post I know someoneās going to say something about it. I have been doing it for 10 years with no issues. Only in the summer cuz Iām out later cuz it gets dark later.
EDIT. I will try to be succinct. I never sleep more than two hours without waking up. Happens to a lot of men over 50. I wake up four or five times during the night. So when I go to bed and I wake up an hour and a half two hours later batteries are done. Turn it off. Thatās my story. Besides that sleep disorder. I am a Very light sleeper.
Good that the 26650 batteries you used allow charging in the middle slot with the 2 outer slots occupied.
I didnāt mention that possibility, because the 3rd 26650 battery in the Vapcell S4 Plus, may or may not be chargeable, depending on what kind of ātopā design is the 26650 batteries. Some 26650 batteries with different top design will not make proper contact when sitted (improperly) in the middle slot of the Vapcell S4 Plus, but some 26650 will.
Also, physically there is no difference for Vapcell S4 Plus (initial batch) versus Vapcell S4 Plus (revised batch) - only some of the chargerās behavior has been tweaked a bit.
Yes, you are right. I have had some 26650 that would not make contact. I have magnets for that and now they will work. Although the high drains Iām using now make good contact with the positive end of the S4 Plus, Iāve had Chargers where I did have to use my magnets. Sometimes itās a combination of the type of positive end on the battery and the positive end on the charger.
