This a picture of my hawk illuminated by the VG 10-S when I went out to feed her after work.
I received the flashlight at a discount from Thorfire a couple days ago. I was offered a choice of lights and preferred the reverse clicky without side E-switch, but they make a similar one that does. Shipped from Amazon. Here is the link Amazon.com
I am going right to what I have been using the light for and what the best use I found for it.
It is similar to many tube lights that run a single 18650, but it has larger cooling fins around the head and a bit more aluminum overall. That makes it a bit big to front pocket EDC and no deep carry clip. I kept it in the side tool pocket of my workpants. (pictured below)
It fits great in a belt holster I bought for my C8 and a jacket pocket or bag.
Here is a line-up of a few other lights to compare size:
I found that it would be good for someone that finds the C8 too big, but still needs more throw and more light at turbo that the smallest 18650 lights provide. That is because in addition to the larger mass and cooling fin design, it is programed to stay on the highest level for 5 minutes rather than the 2-3 of most small lights. It is also different in that it ramps down slowly to the next highest mode rather that stepping directly down. It was running 20 minutes before it was down to medium, and gradual enough that I had to leave the room for a few minutes to notice the difference with my eyes.
It was barely warm after 5 minutes and did not get warmer. I would give this to my son or wife to EDC without worry with a protected or unprotected 2800mAh battery. I ran it on a 3400mAh on high until it started to blink at 3.05V
Run times were as advertised, and seemed brighter than my Convoy S2+ and Sofirm SP31 with the same cell.
Here is a picture of the three sections.
Here is a beamshot of the beehives at the bottom of my property taken with an iPhone. It did not have a tight hotspot, so may not be great for a rifle, but I may mount this to the shotgun.
I hope someone found this useful, and if you have a question, just ask.
I now have more respect for you guys who do real measurements, teardowns,or beamshots with quality gear. I know I will think twice before doing this again.
