Welp after spending about 4-6 hours reading through this whole god blasted thread, I have decided to indeed go with the XPL HI version. From what I’ve read, the Nichia is too diffused/ wide or something. Seems you have to have it pretty high to see anything a reasonable distance away and then you’re at turbo or close to it. I may get the Nichia for indoor usage at some point.
Thank God I just became a flashaholic. Because I’m starting just now when the technology is high, I’ll only need a few lights! Emisar seems to make all I will need!
I have a Thrunite TH20 headlamp to use around the home, Imalemt HR20 headlamp for hiking & awaiting the D1 for long distance beams during hiking. ALL have some sort of ramping. Can’t imagine buying a light without ramping at this point! I’ll be adding the D4, D4VN & FWSE.
Great choice with the D4 XP-L HI, mine arrived a few days ago. Seriously impressive light, great build quality and finish, the best UI I’ve used and the smallest and brightest pocket rocket. Make sure you order the optional 18350 tube.
Firelight2, speaking of mixing emitters… they’re in parallel so it’s a good idea to make sure they all have the same Vf curve. Otherwise they’ll be driven at pretty uneven power levels.
I’ll probably do a mixed-tint D4 sometime soon. I’ve been wanting to do a compact wide-spectrum light, and it seems like a quad works best for that purpose. So, I’m thinking I’ll do 4x XP-G2 or maybe 4x XP-L HI, with emitters at ~3000K, ~4000K, ~5000K, and ~6300K. Aiming for a total mix around 4750K with unusually vivid color rendering (not the same as high CRI, more like artificially oversaturating a picture in photoshop).
For proper mixing, it’ll also need the frosted optic and probably one of RMM’s quad boards. It’ll be a flooder, but it’ll make colors look pretty awesome. My other wide-spectrum quad makes everything look so good it’s almost unreal.
Bookmark that and put a note in your calendar to come back in a year and tell us how it’s worked out.
The thing about an exponential curve (which describes improvements in software and semiconducter hardware including LEDs):
the curve always looks flat behind you and steep in front of you. Wherever you are.
Fakkkk. One day later and I’m already bookmarking about 7 lights (that are out right now) that are on my wish list. You called it!
What I meant was if I became a flashaholic a few years ago, all the lights I’d be buying today would be replacing the older ones because of the updated technology/ more practical reasons. How much more advanced can we get than the most advanced in 2017??
As an example when Smartphones were first introduced there were practical reasons to upgrade with each iteration (to me anyway). Now whenever a new iPhone comes out I yawn. Smartphones cannot innovate as much as the beginning.
So yes I am an addict but not for practical reasons :sunglasses:
And the next thing is already cocking, please read in the Spaghetti Monster thread:
From Toykeeper: Anduril a UI for FSM
A firmware under development similar to Narsil.
Anduril is described in post #3in the thread of Spaghetti Monster (FSM)
Things which still have a lot of room for improvement:
Current lights are still in the range of ~70 to ~130 lm / W, while the theoretical maximum for white light is 300 lm / W. So, that can go quite a bit farther… especially if we find a way to convert heat into usable energy.
Batteries are advancing every year too, which tends to make things interesting.
Driver designs have been getting better and fancier, and there’s quite a bit of opportunity left there… particularly for boost drivers for higher-voltage configurations. And increasing efficiency of moon modes.
High-CRI lights are still not as common as they should be.
Color-related features can be added, plus IR and UV.
Dynamic tint might become a thing — changing the tint from warm white to cool white on the fly.
The ability to change beam shape on the fly might be interesting too, or even adding a laser.
There are still lots of ideas to explore in interface design, especially when using more than just a single button.
Built-in charging and powerbank functions are still relatively uncommon. Other multifunction ideas are also mostly unexplored too.
Auxiliary lights are still pretty simple and uncommon, like a switch/button LED. For example, I still hope to make a tailcap LED board which shows battery state while the light is off.
A few people have added small screens to their flashlights… which might be an interesting idea to explore. I suspect it’s probably of very limited usefulness though.
Extra sensors can be interesting too, like for sensing light and heat and gravity, maybe even sound.
Aesthetics change all the time.
Things which aren’t likely to improve much:
The physical size of each type of light is unlikely to decrease much. This is partially due to ergonomics and partially due to the need for thermal mass to deal with heat. However, higher efficiency can decrease the need for thermal mass.
Physical interfaces have mostly been explored already. Buttons today are mostly the same as they were decades ago. Adding extra buttons or fancier inputs still adds just as much complication as it did in the past.
Logical interfaces are still improving, but on fairly simple lights some aspects seem like they’re approaching an optimal state. For example, many people in different cultures came up with very similar designs for a ramping UI with one e-switch and one emitter (logically, the D4 is only one emitter since all four LEDs operate as one). There likely isn’t much room to improve on the basic operation there.
Basic blinky modes don’t change much over time, and fancy blinky modes have very limited usefulness.
Reflectors and optics don’t really change.
Host materials don’t really change. We already know which materials work best for which purposes.
The useful brightness level of EDC lights has pretty much already been exceeded. My D4 may be able to make 4000 lumens, but most of the time I use less than 200. More lumens can be added, but it’s an upgrade with diminishing returns.
Not a complete list, but hopefully it shows that there is still room left to grow.
Also, while it’s more of a social thing than a technological thing, one big area for improvement is getting companies more aligned with the communities they serve. Making their products more mod-friendly and more based on community feedback. Improving code portability and hardware moddability so people can mix and match whatever hardware and firmware they want. Treating people as collaborators instead of consumers. Encouraging people to get involved.
That social change is the main thing I’ve been working on the past few years.
