That looks like parts from three different flashlights put together.
Has anyone picked up one of these 2-lens FTT torches yet ?
I've got it yesterday. To be honest I don't like it. Especially the beam - no flood nor throw. Double optic in this flashlight worse compared to X2000. Throw is a little brighter than X2000. Zoom system stuck because of finned flashlight body under the moving zoom head. It's impossible to zoom only with single hand because it stuck and diameter is quite big.
Led was not screwed on the heat sink like most Chinese flashlights and thermal paste there was not actually, just tiny drop. I had to drill holes and screw to tight led to heat sink. I wouldn't buy it if I new all of this, actually if I saw beam shots.
Wow.
Were you able to determine if the pill is hollow ? That would be the final straw, IMO.
I left a little review a while ago about it, I tried different lenses with no luck, I don't recomend it.
Where I was able to determine? On the dark place. Just compared with X2000 and not happy with result. Such comparison tolerable?
Unless someone can find a better lens, mine at least will stay on the shelve for a while, I could live with the poor movement on the head if the lens was a good one, but I have tried two new lenses with no luck..
Don't worry yavi! The most important is good heath and GOD bless. Even without any improvements torch is not bad at all. It capable to lite up the dark places and quite a long time. Not all purchase can be successful :)
what is the lens diameter? might be ok for making a fixed thrower?
edit, nm, found it in the other thread, thanks
