What high cri mean?
Are these better than the manafont 3 mode xml's?
What high cri mean?
High CRI means a High Color Rendition Index.
A light with the ability of a light source to reproduce the colors of various objects faithfully in comparison with an ideal or natural light source
A color rendering index (CRI) is a quantitative measure of the ability of a light source to reveal the colors of various objects faithfully in comparison with a natural or standard light source. Light sources with a high CRI are desirable in color-critical applications such as neonatal care and art restoration. Color rendering, as defined by the International Commission on Illumination (CIE), is the effect of an illuminant on the color appearance of objects by conscious or subconscious compar...
Compared to the Manafont drop in they are just as bright, have no PWN, better battery life and you can choose your modes, tint, reflector and maximum amp draw.
fishinfool: scaru:Do you still have the high cri xm-ls? Also are you willing to do custom programming?
What high cri mean?
Color rendering index - Wikipedia
Do you have any of the CRI P60's for sale?
What high cri mean?
Much better than the manafont p60 drop-ins. :) I love mine. 7B XM-L. If you want I can post up a beamshot or two tonight. It is amazing. I got mine with 5 modes going all the way from 3.1 amps to 10 ma. Easily my favorite light.
E1320: fishinfool: scaru:Do you still have the high cri xm-ls? Also are you willing to do custom programming?
What high cri mean?
Sure if you don't mind. I pmed E and most likely will buy one but I still need to decide on the specifics. I really love the manafont 3 mode xml's so I'll probably get something close to them.
Ok, I will take some once it gets dark in a few hours.
Well, I had some trouble getting a picture that was an accurate representation of it.
This is it on high. I just can't recommend this drop-in enough.
Thank you sir. I just ordered one.
JohnnyMac:It only cost me $7 and change to Priority mail a micromag all the way to Australia.
Did you use the flat rate priority box?
Yes I did.
I saw this mentioned earlier in this thread...for those who are still interested, Fancy Flashlights/CNQG has Cree XP-G R5 1D LEDs for $4:
I mailed a Zebralight with box & equipment to Hong Kong, in economy mail and it took 9$ or so
But bear in mind, mailing fees in here are a bit higher!
E1320: JohnnyMac:It only cost me $7 and change to Priority mail a micromag all the way to Australia.
Yes I did.
I guess the flat rate box must be the trick, I will have to try that.
Do you also happen to have blue leds?
No I don't but I see that Manafont has them and if there anything like the green ones they should be very bright.
http://www.manafont.com/product_info.php/generic-cree-blue-beam-led-flashlight-emitter-p-9100
This one? How much current do your green ones get?
On direct drive 1.6 amps at 4.1 volts.
E, I hope you don't mind me invoking the darkside over here, but some dude on cpf is looking for a 2 mode dropin... I figured you'd be the one for that. Only thing is, you have to double your price.
I've been eyeing up the Surefire G2X Pro, specifically for the UI and the Nitrolon, but I don't really need another flashlight. So I'm wondering if anyone here knows of any P60 drop-ins with a similar UI, two mode, Low then High with no memory, and...
2 Mode LED Drop-in | Candle Power Flashlight Forum
No problem, at least half of my drop ins have been sold to new members with one or two posts mostly from CPF, because I refuse to sell them over there.
ruffles:E, I hope you don’t mind me invoking the darkside over here, but some dude on cpf is looking for a 2 mode dropin… I figured you’d be the one for that. Only thing is, you have to double your price.
I'm from CPF and came here after reading a post about your dropins. I don't know if you can make one, but what I'm looking for needs these parameters:
Is that possible at all?
Thanks.
- Low power driver 2.8-4.2v or similar to run on a single 18650 Li-Ion battery in a Solarforce L2P host
- Neutral white emitter, either XP-G R4 or XM-L T5
- 3-modes, Low>Med>High preferably 1/10/100% or similar for outdoors
- NO memory so it always starts on Low
- Current controlled regulation for flat output, no PWM
- LOP reflector for a smooth beam and some decent spill light
Thanks.
Hi bfksc,
Welcome to BLF.
I currently don't have a program like that. If you want to send me a PM we can talk about another program that might work for you.
