One other note Tom; on Match’s data, it is not clear where Vf was measured at. I measured directly across the star wire pads to eliminate wire drop.
I will be testing the drop across the star traces as well. It is possible that the IS-DCB star traces are thicker than the ones on a SinkPAD (I have not compared them yet). That could also be a contributing difference in Vf.
Actually, I just did a quick comparison of the four XM-L DCB stars I have:
SinkPad 20mm star (what Match used) has a ~1mm trace ~5mm long from wire pad to emitter pad, both pos and neg.
SinkPAD 16mm star has a ~2mm trace ~2mm long from wire pad to emitter pad, both pos and neg.
Noctigon 20mm star has a ~4mm trace ~4mm long from wire pad to emitter pad, both pos and neg.
IS-DCB 16mm star has a ~3.75mm ‘trace’ ~2mm long from wire pad to emitter pad, both pos and neg.
Curiosity got the best of me, so I went ahead and tried a quick current test. 6A driven directly from the wire pad to the emitter pad. Multiply by two to get the total voltage drop on the star traces.
SinkPAD 20mm star: 43mV (7.1 mOhm)
SinkPAD 16mm star: 21mV (3.5 mOhm)
Noctigon 20mm star: 22mV (3.7 mOhm)
IS-DCB 16mm star: 14mV (2.3 mOhm)
Nothing conclusive, as I need to do this a little less ad-hoc. It does indicate how Match might have gotten a higher Vf reading.
Edit: It has been pointed out that comparing trace resistance of 16mm boards to 20mm boards is not entirely fair. I tend to agree with that, and was not suggesting anyone do that with this data. I recommend limiting comparisons to within the sizes of the stars.
You know, this could change some think'n around here, that the bigger the star, the better. The 16 SinkPAD is half the 20, and the IS one even better, hhhmmm.
The difference between the best and the worst board is 0.7V, at lower currents that will be lower. That is important stuff for the fine-tuners, that means I am ok .
Even though it may not be of much relevance to my mods, I love data, the more the better, keep it coming !
Funny you should say that. I have been asked by Hank from Intl-Outdoor to do just that. Since I do not have any 16mm XM Noctigons, he is sending me samples.
Hikelite, you are correct, 16mm boards do have shorter traces. However, good trace design can greatly reduce the resistance. Take the two 16mm samples I provided above. The Sinkpad has a thinner trace than IS-DCB and it shows in the test results. The same can be said about the 20mm boards.
As I noted with an edit in the original comment, it is not entirely fair to compare a 20mm board to a 16mm board.
I have completed the testing, and added several graphs and comparison information. I am awaiting feedback from Calvin on the potential reflow issue (i.e. could it be a single unit or a larger issue). I will update the OP when we know more.
Thanks again relic38. I doubt any off us are doing any better on the reflows so consider your data ok. It would be interesting to see these tests conducted on a flashlight with no external cooling and comparing the different stars on different pills in the same light. We need a mule light. It appears that when you get to around 2.8 amps plus that the copper star would be worthwhile. You could possibly get away running an led on a copper star at 2.5 amps with the same output as an aluminium star and led at 3 amps.
Thanks MRsDNF, I think you are right about the aluminium star when driving the emitter to spec. The gains are significant, but not huge. When you want to drive well over spec, the direct bonded stars do their job.
One thing to note is how lapping does nothing, or does it worse. Theoretically it should do nothing since those layers are so thing that for one's mind is hard to even comprehend such thinness, like 0.002mm and such.
I would not say lapping makes it worse. I estimate my measurement tolerance to be at least 5% from test to test, maybe more. These numbers are well within that tolerance.
In theory, lapping away a gap of 0.1mm down to 0.02mm does have an effect, even if it is too small to measure.
I recommend lapping to ensure the surface of the pill and star are flat. Any unseen bumps or machining ridges could hold things apart more than necessary.
Tolerance may be there, the results do show lower numbers, testing such effect several times would give an better idea. Now I am not saying all lapping is bad and one should use surfaces with off road terrain on them. Sinkpad has a big area that does not make full contact and still shows how it handles things very well.
I really like you putting a lot of effort into these tests, but you need some 3.5digit multimeters at least (4000-5000 count at least). I for one will not go trusting too much for that last digit on X.XX only readings.
I do not have time for running multiple tests on each configuration. I barely have time for what I’m doing.
Re: 3.5 digit meters, you are referring to the Vf readings? I will not be going out and buying new meters to add a millivolt digit. I use the same meters for the same test each time, so things should at least compare to each other.
The tests I (and probably most of us) do are not controlled enough to be scientifically compared in an absolute fashion. I just try to control what I can (set things up as close as possible to the same each time) and go from there. The variation in each setup combined with equipment tolerances is where I estimate that 5% (or more) from.
For the 3.5 digit meters, not to add a milivolt to the data results, to make that second milivolt digit more reliable a result. As you know there is not only an accuracy tolerance but also a last digit tolerance on multimeters. Just wanted to clear that up.
