I’ve got these el cheapo UF1508’s with 72mm glass on them.
Changed the drivers and LED’s, can’t think what to now, but I can do at least 800-900 meters on the distant church spire with the one with the smaller de domed LED.
I had three of these lamps, so I took the tubes off and instead of three of them that run two cells, I now have a 1 cell, 2 cell and 3 cell.
Trouble is the beam pattern.
Guessing it is a combination of lens holder and its internal shape, the plastic insert over the LED and the internal faces of the brass pill unit itself.
Any way I was thinking some type of home made Wavien Collar type device over the top of the LED to create a neater output from the LED.
If I do not get the ‘light amplification’ of a proper RLT collar, that would not be so bad, was thinking of seeing what I can find about the workshop / local hardware stores that will be a dome of stainless steel.
Do you think this will tidy up the beam at all.?
I am also going to make a new lens holder…totally impractical for every day carry as it will be way too wide, but somethign like the 3-D design below…something also dome shaped to keep any reflections of light from the sides going out the front.
Take no notice of the LED’s in the pictures, they are the originals, now fitted with …somethg els…de domed, but pattern still like in the first pictures with the multiple rings
Comments please…
Pop a small stainless dome/ wavien collar type device over the black plastic securing ring
What size hole should I be looking at ?
All these surfaces must be what is causing the rings?
Yes this would be the new head to hold the glass…impractical I know, but to prove a point, see if it stops any reflections and reduces the rings. Can always make it smaller diameter at the lower end at a later date.
