Found this cheap little olympia ad180 on amazon that looked like a suitable host. Took a few homemade parts but was able to convert it to a KD triple XP-G2 S2 1A and swapped the driver for the one removed from my lumintop prince.
Two weeks ago I finished testing on a SST-10 365nm led, and I had some 15mm ZWB2 filters around for a year, at the time without a proper host for them. In the meantime I purchased a Jetbeam E10R AA/14500 powered flashlight that works with a 15mm lens (16 actually but 15 works as well). This morning I decided to put the led and lens inside the E10R. On an Eneloop I measured 250mW output OTF, on a 14500 650mW. (the calibration is very rough).
I swapped the stock XPL in my Zanflare F1 with Nichia 219C 4000k 90cri.
The top bezel came off easy, no damage was done but separating the body from the middle section of the light caused some battle scars to the light, it was glued hard.
If anyone is interested how this light looks on the inside, driver, led shelf etc let me know i have few more pictures of it.
Made a copper bezel to replace the black anodized aluminum one on the Astrolux S41 I swapped emitters in, the only copper I had sitting around to work with is some 100% Pure Oxygen free that is hard hard hard! Took a while, but I carved out the little bezel finally.
I probably screwed up, sliced the XP-L V6 3D emitters to fit them under the optic. The tint suffered I think, gotta check it out later when Iāve recuperated some.
That is the right and tricky question. I have been developing several methods for measuring UV led output with a normal luxmeter indirectly by measuring fluorescence. Iām confident enough (for the first time) in my latest method (to be posted within a few weeks when I have time for the write-up) to couple a mW calibration to the set-up. But Iām sure that it is a lot less accurate than measuring white leds, so take my mW number as a ballpark figure.
Not sure of the question vw, the bezel holds down the lens which of course holds down the optic so in that respect I suppose it is sort of a retaining ring. I just remade the bezel out of copper. And then I changed everything else. lol Put a Vishay SIR404DP MOSFET on the A6 driver, changed the leads to 20ga Turnigy, put Richards quad board in it with Nichia 219Cās and fit a Carclo quad optic. Replaced the tail switch assembly with one carrying a mini Omten and a single spring with a Turnigy 20ga bypass.
Sorry Dale I quoted the wrong pic for starters. Your top pic appeared to use a retaining ring on the front bezel, obviously a glare/reflection, but you explained it fine.
Made my first component order to RMM yesterday, not specific DIY kit but individual parts at cheaper quantities. So thanks for listing the details too. Definitely will put the SIR404DP in my digikey cart for later but not enough for now to justify shipping costs. Just learned to reflash the past week and building a driver myself is next.
Have some OshP TA boards here for months, finally getting close to making it happen.
Ah, I know what caused you to think thatā¦ the copper I had here is 100% Oxygen free and is work hardened, itās brutal on the tools. When I was making that finish cut on the face it was grabbing at the cutting tool and left a rough surface, I couldnāt oil it because it was on the light with the emitters in it. I finished it later by hand to remove that rough look.
The copper bezel is made almost exactly like the original only there is a bit more metal out front of the lens, leaving me room for a nicer bevel cut for clean lines. Oh, and the threads fit significantly tighter.
Apparently machining copper is horrible and many places wonāt even do it due to the work hardeningā¦
I have some special copper pieces I need to get CNCd and itās gonna cost $150 to get them done at my university.
$150 for just two pieces about 1ā big!
Titanium or stainless alloys are ways more difficult to work with.
For manual tapping in soft materials you can use āchess tap?ā (not sure how it is called in english, this is tap without every second thread coil).
