Second Astrolux SS arrived recently.
Decided to Fix one up. Both are 3B tint
Stock is on the Left, Fixed on the Right
Right one now has the 20mm MCPCB soldered direct to copper head. 20AWG wires to FET. Bypassed both Springs with braided copper.
The yellow Dim spot in the center of the spot is gone. Halo of the spot is also more white. More better nowâŚ
topping off batts to test current draw on each.
Convoy L2 with short tube, XP-L V6 1A dedomed, FET+1 and 2x spring bypass: nice beam, narrow spot, 280,000 cd at 6 ampere with Liitokala 5200. Handy thrower âŚ
Tint doesnât shift as much doing hot de-dome but it still shifts.
Lot of factors, including freshness of gas, ambient temperature and octane rating. Acetone, seems like that can give more shift than gas but again Iâm sure there are variables.
Hot de-doming takes less than a minute and doesnât stink. Havenât done one in gas in quite a while now.
Today I glued some trits in the lanyard holes of my D25C ti.
I also never liked that the head always needs to be a bit unscrewed for the L-M-H setting. So I put a piece of kapton tape on the battery side of the pill. Now I can keep the head fully screwed in, as eagletac should have designed it :).
Finished my motorcycle auxiliary lights today as well.
xhp50âs in 12v configuration with a 3 amp driver for each. 36 watts from each plus the highbeam from the 7 inch JW speaker copy. Also running upgraded wiring/relays for the headlight.
These lights were used as hosts. Stock theyâre pretty terrible. Tint was completely different between the two, and they came with XMLâs that werenât driven very hard. As hosts they are pretty good. I even reused the optics with the xhp50âs. All in cost worked out to something like $65 USD including a pair of 30A relays and wire.
Iâll get some pics up in the motorcycle thread after I get the belly pan mounted in the next couple of days.
Sorry to spam the thread, but I spent the day playing with my new reflow setup. It sure beats a heat gun/frying pan.
I modded another Thorfire TG06. This one will be a gift to someone who will appreciate nimh compatibility so I kept the stock driver. I swapped the XPG2 for a 5000k 219C. Kept the forward clicky since it works well with the odd stock driver configuration (HLM no memory). Added a bleed resistor to the stock driver. Then another PD68 Rev 5.1 lighted tailcap, this time in green.
I measured lighted tailcap draw on this one since itâs a gift and I wanted to give some idea on drain when not used frequently. This one pulls 0.24 mA from a fresh cell. Configuration is a 19.1k resistor for all 3 channels and green LEDs. Brighter than it needs to be, but my 36k resistors are still in the mail. Going off of info from the X5 group buy thread I expect well over a month from a fresh 650ma efest.
