I agree, I hate charging perfect condition cells at 2 amps, I generally charge them at .5-1 amps tops. I see no reason to stress them out while charging them unless I am in a hurry. In that case I keep spare cells around for a reason.
When reviving a battery in particular though I will at most do 500ma, generally less all the way to 4.2V. Then rest the cell for a week or 2 to see if it maintains the charge before using it.
Any cell that doesn’t maintain at least 4.15v. Dropping from 4.2 to 4.15 is fairly normal after resting but much more is a no go for me unless used in a very low drain application.
At over discharged voltages the copper current collector can dissolve in the electrolyte. Then when the cell is charged the copper re deposits and can form dendrites and cause a short.
Fellows, jomertab wasn't overly prodigal on providing precise information as to what exactly he did and how. I presume he just gave the cell some very brief bursts to raise it to “some” voltage, and then he set it on the charger. I don't know what minimum voltage is required for a BT-C3100 to pump some sort of charge current for a presumed li-ion cell, probably slightly more than the maximum typical value for a Ni-MH; for the same reason, I also don't know what current does it pumps in such a case, yet my guess is “quite low”.
Unless someone can provide with some sort of wise information in this regard, I see no point in those “raise slowly” policies. Little energy is actually required to set the cell in “valid” (2.5+V) territory, so if you're willing to take the risk in recovering a cell, which can be pretty 0K if over-discharged for just a brief while, I'd just give it some little low duty cycle bursts from another cell for it to get into charger acceptable voltage territory. Or use some sort of slow, dumb chinese charger… and take cover! That's about it. :-)
sounds like he spun the cylinder one time too many…
probably a worn out junk cell that had high resistance and damage from overdischarge pushed into thermal runaway by a too high charge rate for even a new cell of that type.
i/o error.
means idiot operator.
Reading the link posted in the OP indicates that the cell was a Panasonic NCR18650 so a quality cell but I couldn’t see anywhere if it was protected or unprotected. Raising the voltage of a tripped protected cell is ok but if it was unprotected with zero voltage then trying to charge it up is in my opinion only asking for bad things to happen.
It reminds me of a coworker who used to reload 9mm by dipping the cases into powder until they were full to the brim. When I asked what powder it was he said he didn’t know and why that would matter.
Of course, that was far from a ka-boom!, more like a bang! or a poof!. And after vacuum cleaner's service, what you see in the opening post's picture is what was left behind, more or less.
Still, jomertab wrote that #37 post all in capitals…
You could argue that it was not the battery’s fault. However the gas tank analogy is not really a good one. Fuel is fairly safe, and requires little care beyond the obvious e.g. do not pour over a person and ignite. And there are regulations governing its use such as a firedoor between an attached garage and a house, and using only approved containers for storage. A lithium ion battery on the other hand is a far more sensitive beast, and there are no regulations governing use. Sure you should not short it, but to use an unprotected cell correctly you need to understand how to use a multimeter, and caring for the battery correctly. The problem is that people do not understand how potentially dangerous li ion batteries are and they are sold by shops that do not educate people properly so storing one in a pocket is commonplace.
There’s no such thing as idiot proof, only idiot resistant. Kind of like water proof, enough pressure and it will happen. Idiots are very persistent in their efforts to sidestep design parameters. I know, I shave one.
So if you rapidly deconstruct a icr cell, your fairly safe, as in exposure to what’s inside ?.
I thought these cells were full of really bad stuff and chemistry needing a hazmat suit and breathing apperates to clean up.
Sound like he just vacuumed up the remains of the cell and carried on as normal
