I thought about that too, as you’ve mentioned before that you don’t test until 2.5V. However, if you extrapolate until 2.5V visually, it still doesn’t seem to have 3000 mAh. This is not the only occasion though. A good example is the Sanyo 2600 mAh that you have tested; it clearly shows that capacity is 2400 mAh, and no way it can be 2600 mAh. I suspect there has to be some kind of scientific tric/philosophy behind this phenomenon; I can’t imagine they’re just messing with us…
Edit: after checking again with the LG, it actually does seem to be feasible to have (close to) 3000 mAh. The Sanyo 2600 on the other hand…
I’m surprised at how short is the CV phase, it takes almost 60 minutes less to charge this than your regular 3100 mah cell used in the charger tests.
That’s my main reason for using high-current 18650’s everywhere, even in low-powered lights. They are surprisingly quick to charge with a 2A charger.
Cyan arent produced anymore, if someone has those on stock they are old
Speaking of greens ofc, they constantly make new revisions, the last one is 12 afaik
The upper one is from the last batch
Its also 1.6grams heavier
As always, nice test HKJ,
now if only our resourceful chinese suppliers could find a was to ship li-ion cells to Europe that would be bliss.
I only managed to get 4 of this cells before new shipping regulations screwed everything.
I have to dig this out because of reasons.
I read somewhere, that the HG2 age pretty badly and that they lose capacity fairly fast compared to the 30Q.
Since GB offers them for €14.02 I would like to know if this is true or not.
I would use them in the Utorch UT03 so I need some good High Current Cells
