Found next mode memory capacitor
3 posts / 0 new
Yoann
Last seen: 9 months 2 weeks ago
Hello,
I would like to permanently remove the next mode function of a driver to only use it at full power.
I saw in other topic that I have to short circuit the capacitor to do that. However, I cannot locate it on my flashlight driver.
Thank in advance you for your help.
unknown00101
Last seen: 1 week 5 days ago
I would bridge them both. That’s what I’ve done with my next mode cheapies that had 2 caps.
Yoann
Hello,
Thank you for your answer.
If I bridge the two caps I will reduce the memory delay depending on the bridge quality (resistance).
Because I need to reduce memory delay under 10ms can I use pencil ?
Do you know if I remove caps the circuit will only work at full power ?
