If first post is saying that item is in stock, this means that it is so with 99% probability.
I can post current stocks photo every week if this is more presentable.
Now to get the funds for a pair of X6 triple ākitsā, been wanting to do this for awhile. Hopefully after Christmas.
Bought a bunch of spacers from him and wow amazing customer service and fast shipping. Great to work with :) his products are best I've seen!
I received a M1 quad kit long time ago but havenāt started my build yet due to a small design flaw, the MCPCB āpocketā is 20mm and because the optic is larger there is no room for it to sit its legs. I think it can be an easy fix using a dremel and cutting disk attachment but I lend mine to a friend, so Iāll probably start the build some time later.
Yes I know about this problem. I had several request from users that wanted to have kit for Khatod quad but didnt had optics and havent realized that it requires āroomsā for optics legs.
You need to mill black marked areas.
Anyway you have got some rare part for good price. Ive made 15pcs only and think that this is all.
A little file work! :+1:
kiriba-ru, received my F13 copper spacer and it fits like a glove! Great doing business with you. Sorryā¦that kinda sounded like ebay feedback. Anyway, this beats the heck out of trying to sand down half a dozen copper disks on my end. Thanks.
I also got my order over the past couple of days. Mine came in two packages and they got split up along the way, but only by one day. Not a big deal at all, and very fast shipping overall. The parts are very nice and a great deal for the money I think, but I havenāt had time to assemble anything but my P60 shell. Iāll report back as the builds come together.
Thanks.
Quad kits for Manker U11 are ready.
I have built 2 SS triples with your X6 Spacers. It works. Just need to understand that the spacer does not touch in the 20mm emitter hole. It touches on the outer edge to the copper body. Here is a pic where it touches, marked in black.
Both of these SS Triples have Glass over optic. One Cute-SS has been sanded and polished smooth which lowered it slightly. Glass is against the smooth optic. The untouched optic has a slight gap between the Bezel and copper Head. Polished optic has no gap.
What does the simple version mean?
Aluminium X6
- Disassemble your U11. Remove stock reflector, mcpcb with led. Save stock wires.
- Use small amount of thermal grease. Put spacer inside (hole should be on the switch side). Pass wires trough hole. Use stock retaining ring to screw it and hold spacer inside, also if you can screw it down near the same level as anodized step in the host means that spacer sits in its place.
- Use quad 20mm pcb. Solder stock wires to it.
- Put carclo 24mm quad lens, brass ring around, stock o-ring over brass ring.
- Put over stock glass lens and screw bezel down.
Bezel is little out from head on mine sample. This means you can use thiner pcb, or sand spacers downside a little if you would like to.
I have spent lots of time and money on this project. Im sorry for very long production time and not very budget prices.
Kirill, I thanked you a while back for the nice packaging and the speedy shipping. Today I finally assembled the X6 spacer with my noctigon triple and the optic. Everything went together nicely and it sure produces light! Thank you.
Iāll post a picture or two tomorrow in the what did you mod today thread. The host is my brown baked EE X6
I received my first package from you todayā¦it had one of the copper spacersā¦for the X5 (I believe), a brass liner, and 3 of the quad optics. My other package hit New York customs yesterday so Iām sure itāll be here in a few days. Everything was packaged very nicely and very secureā¦each piece was wrapped in foam and put in a little plastic box in itās own little sectionā¦then the plastic box was shrink wrapped. Thank you very much!!
Third order i make and receive from Kirill , and Iām very pleased .
Everything new and as promised . Also +1000 on that very good packaging . Thanks man !
Anyone can help me with pill-less C8 internals measurements?
I have a convoy host laying around, what measurements do you need?
Is there a triple/quad optic for the C8?
Hi,
my parts came some weeks ago. Took a while to build all lights. Parts fit perfect, thanks kiriba!
Eagle Eye X7
- 3x Nichia 219C D280
- Ledil-Cute-3-SS Narrow Beam
- MTN17DDm Bistro
- 2700 Lumens
Eagle Eye X6
- 1x XP-L HD
- Kathod PL1672 Ultra Narrow Punch Beam
- BLF X6 Bistro Driver
- 60 Klux
Olight M22 Warrior
- 3x XP-G3 S5 3C
- S2 Spacer + sanded Noctigon XP20 soldered on top
- MTN17DDm Bistro
- 3300 Lumens
Convoy M2
- 4x XP-G3 S4 2D
- Carclo 10621
- MTN17DDm Bistro
- 3500 Lumens
Regards
Kenjii
Great photos Kenjii!
Im not sure that youve got pl1672 from me, anyway what do you think about the beam?
