lol, it is the case even if it showed up 100% correct, working and with an extra light in the package as a free bonus.
Sadly ebay and aliexpress are a scammers paradise for buyers. A buyer NEVER losses a case unless they flat out admit they are scamming the seller, in the official dispute message system. They can call you, email you, text you and even send you a telegram explaining exactly how they are scamming you and that they plan to do it again and they will still win the case.
Once you are on the sellers side of these cases a few times you loose ANY fear of buying online and realize it is truly a zero risk enterprise. Don’t want it or want a discount or even free? Start a dispute over some made up issue and boom, you at worst get a free return, even if the item said 100 different ways, no returns accepted, broken junk.
Or you get a partial refund from the seller in an effort to just make you go away and not have the case escalated. The seller knows they will loose and it is a MAJOR infraction for ebay / aliexpress to have to step in to say the buyer wins, so the seller has to bend over and kiss the buyers behind, no matter how obvious the scam is.
Many times the buyer will simply end up with a free item as the seller would end up loosing even more money by paying for return shipping not to mention he hassle and many times the returned item will be an old item that the buyer simply wanted to “exchange”. So it is easier to just cut your losses and refund the whole thing.
Sadly buyer know this to be the case and abuse it far to much.
As a buyer myself I simply buy without fear of any kind. I just keep in mind that while I can get items for free, it hurt the seller way more then people like to think unless it truly is an issue.
TA, do you think eBay and the like have a warning system to identify such people? For example if %75 of purchases over the last month have been disputed, they lock the account. I would think they would have some way to monitor this. They are not dumb to it so I wonder if they keep an eye out for this behavior?
Yeah, they claim to do this but I nor any other seller I know has gotten more then empty promises from them that they will look into it.
I mean if someone is blatantly ripping sellers off right and lift then there have been a few cases I know of where the buyers account was suspended. That doesn’t help any of the sellers he scammed though and he just creates a new account and does it again.
Sellers on the other hand, watch out, just 1 or 2 infractions can be enough to ruin your account standing and thus your ability to sell anything. Particularly low volume sellers.
Nah, pretty normal. I generally have this happen with my orders. You are penalized if you do not ship things on time so rather then actually shipping things on time most sellers system automatically buy a shipping label and say it was “shipped” even though no human even knows something sold yet. Pretty standard operating procedure now days sadly due tot he heavy penalties of shipping something later then you stated.
Now the price is on $38 like the codes on banggood.com.
A solution for the other head is change the leds and rasp the optics a bit down, that there can not be contact between optics and LED.
The other solution is to get a refund because of the wrong description. I have ordered one for the low price.
I’ve been using a first batch S41S with Nichia 219B as an EDC for about six weeks now, and it’s still OK. It gets a few minutes of use every day, mostly on the 50lm level, but I have run full test cycles on turbo as well.
The only glitch I’ve seen is that it occasionally drops into the configuration menu when I’m changing mode. I suspect ropey switch debouncing.
On a related note, one of my two original black aluminium S41 lights has failed after virtually no usage; it starts jumping around between random modes after it’s been on for a minute or two. Alternatively, Banggood may accidentally have shipped me a prototype of the never-released Astrolux S41 Limited Edition Christmas Tree Light
can anyone confirm that XP-G3 is quite hotter than Nichia version at the same amount of time period.
my xp-g3 version gets quite hot in even level 4 than the nichia model within about a minute.
I have seen that some say thermal paste is not enough and led plate does not touch the copper part properly and it cause the extra heat. is that true??
If there are problems with the heat path such as no thermal paste or port contact of the mcpcb to the host, the host will actually feel much cooler while your leds burn up. The faster a light heats up the better the thermal path. So in your case, the nichia host would be the one with problems, if there is a problem at all.
Not necessarily.
The MCPCB will get much hotter and the efficiency of the LEDs will be bad, so in all there will be more energy transferred into heat, and the only way the heat can go is the pill, so eventually the light will get hotter when there is bad heat transfer to the body.
I’m confused. I’ve just ordered the S41S, will I be able to use its head with my 18650 S1 tube (wich has 0,95 mm pitch)? I thought so because according to this http://www.banggood.com/it/Astrolux-S41-Astrolux-S1-LED-Flashlight-18650-Body-Tube-p-1054468.html at least S41 and S1 should have common threading… but now it seems that the S41S matches the S2+ body, which I also have and I confirm that has wider threads (1,2 mm pitch). So how is this thing?? does that mean that S41S and S41 have different threading? :s
