ENEDED
My order was marked as shipped almost immediately after I placed the order. Hmm? Think the seller wanted to get them out before word got around?
Yeah, they claim to do this but I nor any other seller I know has gotten more then empty promises from them that they will look into it.
I mean if someone is blatantly ripping sellers off right and lift then there have been a few cases I know of where the buyers account was suspended. That doesn’t help any of the sellers he scammed though and he just creates a new account and does it again.
Sellers on the other hand, watch out, just 1 or 2 infractions can be enough to ruin your account standing and thus your ability to sell anything. Particularly low volume sellers.
Nah, pretty normal. I generally have this happen with my orders. You are penalized if you do not ship things on time so rather then actually shipping things on time most sellers system automatically buy a shipping label and say it was “shipped” even though no human even knows something sold yet. Pretty standard operating procedure now days sadly due tot he heavy penalties of shipping something later then you stated.
ouch, that’s some bad news :s
I also ordered one yesterday… so, if I understood well, there are only two differences:
1) the head was modified this way:
to prevent the opticts to crush the leds
2) no more threadlock
am I right? did anybody find a good solution for problem #1?
Now the price is on $38 like the codes on banggood.com.
A solution for the other head is change the leds and rasp the optics a bit down, that there can not be contact between optics and LED.
The other solution is to get a refund because of the wrong description. I have ordered one for the low price.
I would think someone has found a good solution or modification that allows using the same leds?
Are all the old version non-functionnal or can we get lucky ?
I bought two new/old versions from the aliexpress’s seller and i am not really happy about it… :person_facepalming:
Mine (S41S Colored with Nichia 219B) from the first batch actually still works and I have “tortured” it at least a bit.
I’ve been using a first batch S41S with Nichia 219B as an EDC for about six weeks now, and it’s still OK. It gets a few minutes of use every day, mostly on the 50lm level, but I have run full test cycles on turbo as well.
The only glitch I’ve seen is that it occasionally drops into the configuration menu when I’m changing mode. I suspect ropey switch debouncing.
On a related note, one of my two original black aluminium S41 lights has failed after virtually no usage; it starts jumping around between random modes after it’s been on for a minute or two. Alternatively, Banggood may accidentally have shipped me a prototype of the never-released Astrolux S41 Limited Edition Christmas Tree Light :stuck_out_tongue:
Well, fingers crossed, i guess. :wink:
Anyone know a summary of the reported problems with the first version?
can anyone confirm that XP-G3 is quite hotter than Nichia version at the same amount of time period.
my xp-g3 version gets quite hot in even level 4 than the nichia model within about a minute.
I have seen that some say thermal paste is not enough and led plate does not touch the copper part properly and it cause the extra heat. is that true??
ASTROS41S - invalid promo code… any updates on the code? thank you :slight_smile:
If there are problems with the heat path such as no thermal paste or port contact of the mcpcb to the host, the host will actually feel much cooler while your leds burn up. The faster a light heats up the better the thermal path. So in your case, the nichia host would be the one with problems, if there is a problem at all.
I see: ok the optics, but why changing the leds?
Not necessarily.
The MCPCB will get much hotter and the efficiency of the LEDs will be bad, so in all there will be more energy transferred into heat, and the only way the heat can go is the pill, so eventually the light will get hotter when there is bad heat transfer to the body.
That’s true though.
I’m confused. I’ve just ordered the S41S, will I be able to use its head with my 18650 S1 tube (wich has 0,95 mm pitch)? I thought so because according to this http://www.banggood.com/it/Astrolux-S41-Astrolux-S1-LED-Flashlight-18650-Body-Tube-p-1054468.html at least S41 and S1 should have common threading… but now it seems that the S41S matches the S2+ body, which I also have and I confirm that has wider threads (1,2 mm pitch). So how is this thing?? does that mean that S41S and S41 have different threading? :s
I’m sorry but that’s just not the way it works. If your s41 has an mcpcb that is separated from the led shelf your emitters will fry before your light barely gets worm. Ask me how I know;)
Convoy S2+ does not fit Astrolux S41S
the user I quote in my last post wrote it did fit :confused: so you think it will not fit the convoy S2+ but it will instead fit the astrolux S1? (which is what I’m hoping for, of course. For the option of using the 18650 tube but also to use the aluminum 18350 tube+tailcap to shave some weight)
