i have triple xpl and also nichia sets,if you need height…also on the new copper board…
Yes, please measure height (without extra legs length).
height of the legs?or the complete sets-legs joined with the board?the sizes are not posted on kaidomain exactly?
Welcome,
Wanted to point out a few observations on this one before it gets glued together.
The S2+ is assembled from the rear, total size is not as critical as on the S3. S3 only has so much room and no way to compensate.
I honestly have not tried to assemble it with the single emitter stack. Guess I should try before it all gets glued to triple.
OK, Single stack works but there is a small gap under bezel using the Noctigon and XM-L spacer. I also have the O-ring on top of glass. Thinner MCPCB or no O-ring will seat the bezel flush. Guess if your skill level is higher you could also use a flat pad spacer or omit the reflector spacer all together. Space is tight in there.
complete set without extra legs length.
8,45 mm said my friend,who measured it right now…
I don’t think this is right , this height you mentioned should be with the extra legs length .
I measured 7.15mm .
@kiriba-ru. Finally built my triples using the spacers you supplied before Christmas (had to wait for KD to reship the LEDs). Spacers were a perfect fit. Thanks!
As I said, poor customer service.
Not everyone uses a part the day they get it. Or even the same YEAR. That doesn’t excuse rude, dismissive behavior. I’ve made literally thousands of purchases and your response ranks among the top 5 worst. Thanks for confirming my statements.
Think I am up to about 10 builds using Kiriba-Ru parts.
Today I finished the Convoy S3 Triple. Good Stuff and Packaging, fast International shipping.
I would think there is some reasonable expectation to inspect the part upon delivery or very soon after.
Parts were fine on arrival with a quick inspection. Domes fell off into the baggie while just sitting in a drawer with other parts I was gathering. I’ve NEVER seen domes just fall off before and would not even think to check even periodically to see if it happened. Nevertheless, I stand by my statement.
I’ve built 3 triples using these parts and the integrated shelf S3 hosts, all worked perfectly.
With Glass? I had to omit the glass lens.
has anyone measured : kaidomain triple setup vs triple noctigon +carlo ?
Seems that KD sets are 0.2-0.4mm lower.
not big deal,thanks.
asked again and he said 7,45mm….
I’ve received my order for a copper spacer for an Astrolux SS. The shipping time was great (very fast!), nice packaging, and great fitment. Thank you!
I would like to order the following. Can you recommend how to split shipments to reduce costs?
Copper spacer for Carclo triple Convoy S2+/S3/EagleEye X2/BLF A6/Astrolux S1,
$5, 17g
Brynite B158 copper pill,
$14, 39g
P60 copper quad drop-ins – Surefire non-compatible, no ground sping required, driver press fit/solder version
$16, 56g
0.5m of pure copper foil:
$2
triple liner with gitd o-ring (also fit my previous drop-ins)
$4
^ Is this required for SolarForce P60 quad build?
Carclo 10622 24mm quad Narrow Spot Plain TIR
$1.50
Thank you!
