I’m about to order Rev5.3 will post if I get it working in a build thanks PD
I added a lighted tailcap to a Boss35:
….except not really, because its actually much dimmer than this in real life and I can’t get it brighter without freaking out the driver. Lower resistance in the tail is a no-go, adding a bleeder causes all sorts of malfunction. So unfortunately it came back out and my Boss35 won’t be sporting a lighted tailcap.
If anyone else wants to attempt something similar though, these boards can be made to fit a McClicky switch. I used the 5.1 “big switch” ring board in 0.8mm thickness, then dremeled away basically everything but the traces. The switch body has to be thinned slightly too, and machined out underneath the ring board to clear the resistors. If this light had a driver that would accept a bleeder it would be no problem.
Also posted in another thread:
I was never able to do the lighting tailcap in triples with low voltage leds (new Oslon Square, Nichia 219C, XP-G3) in combination with BLF-A6 or bistro drivers. But now that I know the fix for the bistro driver (pyramid with C1, D1 and extra 5 Ohm resistor) the lighted tail can be done! . The above light has 4x219C and fixed X5/X6 driver from Banggood, 470 Ohm bleeder, 3x 4 KOhm resistors on the 6x dumb tail ring with red 0603 leds and red silicon cover.
I have not checked yet how the ‘fix’ +lighted tail works for the BLF-A6 driver in this same set-up.
Looking on ordering some to mod, what’s the best version u guys like ?
I prefer Rev5.1 which is good for most of the Convoy single 18650 lights like S2+ and C8. Now I put in white leds on all boards and do the coloring with tailcap rubber’s color. Easy to swap colors if you bored with one.
What bottom board did u use
Whatever comes in the light, usually. Unless you want a pot or something like that. The v5.1 board will work great with any mini-omten switch board (and others with some work)
I use the 5.1 and 5.3 combo myself.
I use the stock with the light or in triples I use PD68’s high current switch board.
What’s this fix you talk of? I ask as I have had lots of problems with getting the illuminated tailcaps to work in a triple 219C Convoy S2. The off timings go from normal to impossibly short (requiring faster and faster half-presses to switch modes) when it heats up.
Not sure if it’ll fix your issues, but here’s a post where he discusses it:
Exactly what I was looking for, thanks!
Maybe I’m missing something obvious and my lights are borked too, but I’ve had no problems with Bistro driver triples and lighted tailcaps. Is it because I’m using Richard’s mtnelec driver or should I be more aware of some issue I may not be noticing?
So after reflowing a whole new DD+7135 driver (eliminating all parts but the LEDs as the source of the problem) and doing the X5/X6 driver fix with an extra resistor 10k resistor, the temperature sensitivity issue is STILL present.
I used a 750 ohm bleeder and 10k tailcap resistor driving 6 white tailcap LEDs which work normally (when flashlight is cold).
OTC values are: CAP_SHORT = 245, CAP_MED = 130 (I prefer a fast medium press time)
Out of curiosity, has anyone else experienced this problem? To test, get a feel of how quickly you need to half press to move up and down modes. Heat up the flashlight with turbo mode until fairly warm, then try switching modes again. If the issue is present, the flashlight will either switch down modes or not switch modes altogether.
My hypothesis is that the OTCs supplied by RMM [0805 1uF X7R Ceramic Capacitor] I’ve been using are heat sensitive and thus drain much faster than normal when hot.
The fix of the X5/X6 driver, as suggested by DEL, reduces the voltage spikes on the MCU and fixes the drop to low when switched to TURBO, and as I found out it (perhaps coincidentally) makes a lighted tailcap possible without screwing the UI. Reducing the temperature sensitivity of the driver is not mentioned for this fix.
As both drivers (Wight DD+7135 and mtn FET+7135) work fine without the X5/X6 fix, it must be unrelated. In any case, I didn’t notice a change between fix/no fix. Nobody else seems to have seen this temperature issue surprisingly. Maybe nobody with a lighted tailcap has driven their light hard enough to see it?
People mistakenly think it is bistro that is the issue when it is actually the X6 driver design that is to blame. That was before we started adding the extra components to fix the voltage spike issues. Namely the resistor before the diode.
RMM took a different approach, instead of stopping the voltage spike he bleeds it off via the zener diode.
These drivers work well with single higher voltage leds (i.e. the XP-L Hi in the BLF X5 and X6), the drop-to-moon problems arise with the newer low voltage leds (i.e. 219C, XP-G3), and possibly even just in case of triples/quads.
Ah, so it’s not me. Richard’s driver is better. Got it.
Also since it’s being discussed, my high powered lighted lights do exhibit some switch timing changes, like others have said. They get shorter, but not much. Really I have to be looking for it to notice.
Seems that the same temperature/heat issue has been reported before at page 23 of this thread. Seems odd why it only happens with a lighted tailcap. The workings of the OTC is strange beast indeed…
