D.I.Y. Illuminated tailcap
  • I’ll start by saying that while sometimes I’ll sell a light with one of these pre-installed, I am not currently taking orders for them. If someone else offers to build one for you, go for it. I won’t attempt to restrict it in any way, though I try to make it as accessible as possible for people to build their own. This is still a project in motion, often being updated/upgraded. So if you have an idea to make it even better, please let us know.
Below is a brief overview. I recommend reading through the whole OP, then asking any questions in the thread below. You will get a faster answer here than if you PM me.
  • Vampire current has been measured as low as 0.02mA
  • All resistor and LED pads are 0805 sized.
  • Oshpark is currently offering a 0.8mm thickness in addition to their default 1.6mm. I recommend always getting 1.6mm for any ring PCBs, as they are under most pressure. For the base switch PCB, be sure to measure your host to see what thickness will give the best fit.
Driver Modification.
This isn’t exactly “good” science. I don’t understand all of the ins and outs of how this affects drivers, but we have learned quite a bit from experience. Some drivers will work just fine without any modification when the Illuminated tailcap is added. I’m sure there are some drivers that simply won’t work correctly at all after it is added. Most drivers will have issues initially (like not changing modes when the switch is pressed) but will work correctly once a bleeder resistor is added. This is a resistor placed on the driver directly between Battery+ and GND (the flashlight body) to “bleed” power past the driver to the tailcap. It can be placed in a number of different ways on the driver. The needed value is typically between 500-800ohms, but will depend on how much power your tailcap draws. If you already have a bleeder resistor and still have problems, try a bleeder with lower resistance.
Here are some pictures of the bleeder placed different ways.
In The Tailcap
Generation 1
I highly recommend using a Gen2 design as they are much more efficient
This is where it started. In case you were wondering, the design Banggood placed in lights like the X6/X5 and the Cometa falls into this category, and is most similar to my Rev3 design. The generation 1 boards include Rev1-4 and pyro1son’s design. They consist of a single PCB on which you mount your switch (ex. Omten 1288), your resistors, and your LEDs. You then replace the typical steel retaining washer and opaque tailcap boots with translucent ones. A replacement washer can be made yourself or bought from a few places as can clear boots. See the links at the bottom of the OP.
The Rev3 design requires resistors to set your tail brightness. The needed resistance can vary anywhere from 1kohm-25kohm. The Rev4 and pyro1son’s boards introduced pads for 3x3 potentiomers to more easily adjust resistance. We recommend getting 25k or 50k rated pots to get the best range. These two versions also allow you to adjust the brightness after installation, without completely removing the whole assembly.
Gen1 boards use more power than the Gen2 boards because more light gets trapped inside the switch area.
Rev3 - Simple dual-resistor dual-LED version. LEDs and resistors are in parallel, but a trace can be cut to separate the two sides. 17mm and 20mm - Info in Post #263
Rev4 - Dual pots to adjust brightness of a dual LEDs, and a mini slide switch in the spring to adjust quickly. 16mm and 20mm - info in Post #566
pyro1son - Dual LEDs and a pot in the spring to adjust quickly. 16mm and 17mm - Info in Post #555
Generation 2
This includes Rev5 (and its many sub-revisions) and the still mostly-untested Rev6. They offer greatly-improved efficiency because they replace the retaining washer with a “ring” PCB, and mount the LEDs right there under the cover. This gives back most of the light we previously lost down in the switch. It also offers more room for more LEDs and color options. This ring includes pads for resistors right there with the LEDs, so you can pair it with any standard switch PCB. You could, however, pair it with a Gen1 base PCB (or the Rev5 PCB) to combine the efficiency of the Gen2 “ring” design with the easy control of the Gen1 pot/switch features. Because these are more efficient, you will probably want more resistance to get a usable brightness. I recommend 10k-30k for resistor values and 50k+ for pots.
This is the type you must use if you want to install in an S2+ with the metal switch. However, that switch design blocks much more light than a rubber cap, so be prepared for much higher power draw than in other lights.
Rev6 is the version that has an Attiny13 mounted in the tail, but as I said it is mostly untested.
Update: In addition to my own designs below, now there are options available made by Led4power and/or Lexel
Rev5 - This is a base PCB to give more function to the “ring” type PCBs. It is very similar to Rev4 but with wire connection pads instead of LED pads. 16mm - Info in Post #691
Rev5.1 - Supports six LEDs on three channels, each with their own resistor. Can be used with any switch PCB or paired with Rev5 or pyro’s PCB for more control. 16.5mm - Info in Post #746
BIG SWITCH - This is identical to Rev5.1, but larger overall to work with larger switches, like the Omten 1217 or some forward-clicky switches. The center hole is 8.4mm diameter, and all bottom pads should clear a 12mmx12mm switch body. 19mm - Info in Post #1064
Rev5.2 - Supports six LEDs on two channels, each with their own pot mounted on the ring. Can be used with any switch PCB or paired with Rev5 or pyro’s PCB for more control. The two channels can be merged or the pots bypassed with jumpers. 16.5mm and 18mm - Info in Post #1050
Rev5.3 - Set of both Top and Bottom boards. Top supports six LEDs on two channels, each with their own balancing resistor that can be paralleled or bypassed. Connects to the Bottom board with standard 0.025” header pins through matching vias. Bottom is similar to Rev5, supports dual pots and mini slide switch. 16.75mm Top and 16mm Bottom - Info in Post #1184
Rev5.3 Pot - This is an alternative to Rev5.3 Bottom. It is similar to Pyro’s board, with a single pot in the middle of the spring. It also connects to Rev5.3 Top with header pins. 16mm - Info in Post#1256
Rev6 - Untested “smart” ring design with MCU and six LEDs all in one package. 19mm - Info in Post #729 and #743
Note: Rev5-6 are designed around the dimensions of the Omten 1288 and probably won’t fit on anything bigger.
LINKS
These links may be where I bought mine from, or just a good example to show you what you are looking for. In any case, most of these items can be found from many sources all over the internet.
Omten 1288 switches: MtnElectronics , Kaidomain
Translucent Spacer (5/16 Nylon washer) at Home Depot
Various Switch Covers/Boots from Kaidomain
16mm Clear Switch Cover/Boot from Simon
Lighthouse LEDs
Cheap resistor pack from Fasttech
50kohm range 3x3 potentiometers on ebay
Small slide switches for Rev4, 5, and 5.3 boards on ebay
Original thread
Pre-Built LED Tail Cap Buttons for Convoys
Lighted Tailswitch
Astrolux Hosts listed at BG
Lighted tail switches on a C2+ w/ Biscotti
Transformation T̶u̶e̶s̶d̶a̶y Saturday - Convoy S8 Mod - Updated 1/17/16
Clear anodized Convoy S2+ (switch poll closed) now just discussion
SOLD: Custom Convoy S2+ mini - Triple XP-L
Help, tail light switch of pilotdog?? Prefer answer from Mr. pilotdog
My 2300+ lumen Solarforce L2n + DIY Quad P60 spacer
BLF Kronos X6/X5 GB - Group Buy now closed.
Astrolux S3 / SC Hosts on Preorder $14.99 / $26.99
MTN Electronics: LEDs - Batteries - Lights - Chargers - Hosts - Drivers - Components - 1-Stop-US Source
Review - Astrolux SC Copper 14500 Flashlight
Switch bypass on convoy S2?
Code now public! BLF A6 FET+7135 Light. Short 18350 tubes and Unanodized Lights Available
Review: Manker E14 Quad Nichia
Texas Avenger 30mm & 46mm PCB's + lighted tailcap kits
CURSE ON YOU , BLF Members !!!
Oshpark Projects
L2X Clone, Small Sun ZY Build
Iluminated Tailcap + Adding memory to a flashlight
Modified Lights For Sale (10 for sale)(5 left)
Is an illuminated tailcap possible?...... Solved?
Convoy S2+ Mod With A Lighted Switch
Project YETA F13M
hi dear,could you tell me why you want buy China items not via AE
GFS16 - Battery Indicator Tailcap Light & 1mR FET Tailswitch! (Rev B)
Lighted tailswitch for my favourite 18650: Astrolux S41S Stainless Steel
different power consumption for lighted tailswitch in Convoy S2+?
Convoy s2+ wonky from new, need some advice
CF FX17A driver: How to switch modes??
Flashlight Firmware Repository
convoy s2 question
Deals on Mosquito killers (light related) :-}
gChart's 500 post giveaway - winner announced
Convoy L6... XHP70 Beast!
BLF A6 Tail cap switch
Sofirn Special Deal for Father’s Day on Amazon.com: 11, June to 15, June 18650 flashlight at $10.99
The glow and dark bling thread
Convoy C8+ New look for an old favorite
Hello from the Netherlands
What did you mod today?
Convoy C8 Mod - The WOW Factor
Convoy S2+ Desert Tan Available Now!
Selfbuilt's Mateminco SL02 EDC review
A few things for sale - ALL SOLD
Put a sensor on it so it only lights up when you whistle for it...
Picture of your current switch board?
Omten 1217 seems a bit tight on a 17mm board.
Flash will be easier to locate than constant on, lower power use too.
I thought the 1217 was the standard switch that people used? I don’t have one currently. What switch do you suggest?
I mean the body of the Omten 1217 is already ~ 17mm and thats without a place to solder the tabs. If you fold one tab around to the spring side and solder it there you might get close but it looks like it will still be over 17mm. If it must to fit within 17mm then I’m not sure if the Omten 1217 can work. I checked the Omten 1217 thats in one of my lights and its on a 20mm board.
What switch is in the lights that you’ve been testing with the tail led? Board diameter? Could you post a pic?
Do you think the 1288 is a better fit?
The one I’m testing on is a forward clicky from a SF L2
I do have another 17mm one that the switch almost completely covers, probably similar to how the 1217 would look
Well, looks like some hang over is ok for that flashlight at least. So what diameter would you like for the center spring pad?
Well I want this to drop in and work in as many different lights as possible, so If you and others think a smaller switch would be better I will follow your wisdom. I just thought the 1217 is the go-to switch. That particular large switch came from an ebay light, and I will admit it was a royal pain to resolder under itself.
It could be easier to solder. New omten 1217 switches comes with one long tab. I placed a slot in the middle for the tab to pass through. The second tab can be folded over the edge. Then both could be soldered from the spring side. Spring added after that.
Whats the diameter of your springs?
I generally use whatever I pull off the old switch, but I have both 9mm base and 7mm base springs on order from cnq and fasttech.
9mm looks like a good size.
https://oshpark.com/shared_projects/qG9BSs07
17mm diameter board. 11mm spring pad.
If your 1st picture is an accurate indicator of the size LED you plan to use, I would suggest a smaller SMD like an 0603 there must be a way of mounting on the button and under the button cover.
I’m not sure what you mean? The led in the picture is a 5mm from radioshack that I was using to test the concept. It won’t be in the final version
Helios! Thanks, that looks great…. Except for one part. It looks like you have the resistor between the battery and the led, but the resistor should be between the body tube and the led.
Nice Helios, more or less going to fold the tabs of that OMTEN 1217 over and surface solder to the backside?
Worse comes to worse a few hits with a hobby file might clean up the edges if the clicky is too large
You can place resistors before or after an led.
I put the led at the body since you wanted through holes. Then only one pin needs to be isolated, the other pin is connected to the body. You can solder that pin from the battery side, seemed a bit easier.
Ok thanks for explaining. I’m still a bit of a newb on circuits if you can’t tell. The large pads on the top should allow use of smaller switches too.
I’m ordering 3 of these right now.
One tab, the long tab on new omten 1217 switches, would be folded under the switch and passed through the slot in the center of the board. The second tab is folded over the edge of the board. Gave the board a flat tire shape to give a little more clearance for that tab, in case room is tight in the tail.
You can then solder both from the spring side and add the spring. Instead of having to solder under the switch. As pilotdog mentioned its a bit of a pain to solder under a switch.
Very nice! Wonder if these could be used for some of the el-cheapo tailcap clickies w/ those weird spacers… (or maybe I am visualizing something different)
Either way…awesome assistance there Helios…good job!
