I am big on Neutral White Tints hence the 4K Selection… I also love Nicha’s but couldn’t find any stock on a 20mm of those temp colors up at Mountain… Or anything between 3800K and 4K… If you have a place please link me
Alternate Firmware: Flash STAR FW OFF-TIME WITH MEMORY
Increase/Reduce Driver Current 7135: Remove (8) 7135 Chip
My FW Selection (1) 2% - (2) 15% - (3) - 50% (4) - 100% + Memory + Turbo Step down of 60 Seconds.
Copper Breaded Spring
I am also looking for somebody willing to build me an illuminated tailcap:
I dont have the tools nor the hand to solder this small after my surgery this past weekend…
So I am willing to pay someone to build me one for the F13. (Note: Will I need to go with a different driver if I go this route?)
I am open to recommendations and constructive criticism!
Thanks again!
Thanks for your reply!
I thought about it… but does that mean I need to go with a different driver?
Can you recommend me a driver that would drive this config?
You could use the same driver but with all the 7135 chips at 6Amps or you could choose a FET+7135 driver for higher turbo and shorter runtime (assuming 22mm is the right driver size, taking your word for it)
If you go the lexel route he can certainly make probably anything you would ever want and can advise you what changes to make for a triple. I would probably tell him if you want to prioritize runtime, brightness, heat and if you want a moonlight mode or not.
