Review: Manker E14 Quad Nichia
Manker E14 is an EDC flashlight powered by a single 16340/®CR123/18350 battery with maximum output of 1600 lumens on CREE emitter and 1400 lumens on Nichia. It has quad LED emitters with TIR optic and copper head that give it a distinctive look.
I receive a sample of Manker E14 from Gearbest for review purpose and have been using it intensively for about 2-3 weeks. It’s the Nichia version and I can tell you how much I like its tint color.
Here are the main features of Manker E14:
  • Small functional flashlight with detachable two-way clip, fits in your pocket.
  • Utilizes four LEDs of CREE XP-G2 (6500K) or Nichia 219B (5000K).
  • Maximum output is 1600 lumens for CREE and 1400 lumens for Nichia.
  • Circuit driver A17DD-L FET+1 Driver
  • 2 groups output modes, user toggleable mode memory and mode groups.
  • IPX8 waterproof.
  • TIR lens, floody output.
  • Copper head for better heat dissipation and strong aluminum body.
  • Compatible with 1 x 18350/16340/CR123A/RCR123 battery (not included).
  • 18650 tube is also available separately.
Unboxing Manker E14
The content of the package is quite complete.
I got a flashlight (of course), a reversible pocket clip, lanyard, spare o-ring, spare rubber boot switch, and two sheet of papers (feature list and operation instruction).
The head was a shinny copper out of the box. I took this picture after one week usage and you can see that patina started to develop on its copper head.
The original copper color is identical with the color of the fin’s groove.
The body is made from thick aluminum and the diamond knurling is comfortable to grip.
The rubber tailcap look strong and I think will last for couple of years.
Disassembling Manker E14
Unfortunately, the threads on head aren’t greased at all. I applied some Xeno grease to all the threads before using this flashlight.
Later, I found some reddish “powder” mixed with the grease on thread. I guess the manufacturer didn’t clean the copper properly and residues are left behind.
And here’s the charm, four Nichia LEDs with TIR optic. Georgeus!
The contacts are made from gold plated metal to ensure better electric conduction.
The springs aren’t by-passed out of the box like Convoy L6, so I will by-pass them later to get more output.
I opened the switch and found pilotdog68‘s circuit is inserted there. With a little soldering skill, we can hack the rubber switch into a illuminated tail cap.
As I mentioned earlier, Manker E14 is compatible with several battery size. I inserted a 16340 battery and you can see the gap here.
But thanks to both springs on head and tailcap, the battery is kept steady inside the tube. No rattling.
Operating Manker E14
Manker E14 has two group modes:
  1. Moon – low – mid1 – mid2 – high1 – high2 – turbo
  2. Low – mid – high – turbo (short press for less than 0.5s) + moon – turbo – strobe – battery check – bike flasher
Operating Manker E14 is a bit tricky at first. There’s a short press and medium press, it took some time to understand what is short press and what is medium press.
It’s recommended to use Manker E14 with IMR battery to get its best performance. I was unable to take beamshot pictures because the lack of IMR batteries.
Using non IMR battery, I can barely see the difference between mid1 and mid2, as well as high1 and high2 on first group mode. I will update this post with beamshot pictures after I received my IMR batteries within few days.
After a couple of weeks using Manker E14, I decided to use group mode two with memory off. You can read how to change group mode and how to enable/disable memory mode at the end of this article.
Manker E14 for EDC
The dimension of Manker E14 is somehow ideal for EDC flashlight. It’s a bit heavy but still acceptable.
Here’s side by side picture with Olight S1 Baton and a RCR123 battery.
They’re my current EDC setup nowadays.
Unfortunately, the clip is a disappoinment. I tried to put the clip but it didn’t work well.
So I carry Manker E14 inside a custom leather holster as you can see on following picture.
Changing Group Mode of Manker E14
As mentioned before, I will end this article with a mini tutorial on how to switch group mode and disable/enable memory mode.
  1. Turn on Manker E14.
  2. Tap the tailswitch for 18 times until the LED is flashing.
  3. Turn off the flashlight in between first two blinks to change group mode, OR
  4. Turn off the flashlight in between second two blinks to enable/disable memory mode.
  5. Done.
I succeeded to change the group mode on second attempt, so don’t give up if you’re unable to do it on your first attempt.
If you’re interesting in purchasing Manker E14, you can use these coupon code to get the best price:
  • NICHIA 219B 5000K 8% OFF
    Coupon: GBLED2016
  • CREE XP-G2 6500K
    Coupon: ManE14G
reserved for beamshot pictures
Thanks for the review!
That patina looks “speckled”
Seen that effect on other Astrolux lights as well.
But on the old copper things we have (round 70cm table, several pans, some little figurines, cups etc), copper PC cooling stuff and on copper pipes I have never see it like that. What could be the reason for such different behavior?
Looks like straight up copper to me. My E14 has been coated with something so no sign of patina.
Thanks. I enjoy the way you present the information in this review. It is not extensive as some others but several of the points that are of most interest to me are very clearly gone over. I have had this light for some time and was still a little unclear about the UI functions. It seems that the only reason it is hard is because nobody plainly states how the interface works.
Like I said, I have this light too. The first thing I tried when I got it is using a BLF a6 or any Astrolux variants 18650 tube. Fits perfectly. The light still remains surprisingly compact and 3500MA is highly preferable to 700-800.
I have one and I am very happy with it.
You are really missing out by not using a good 18350 battery in the E14.
Bob
I remembed that another thread on this forum discusses about this (I couldn’t find the thread at this moment), it seems that Astrolux/Manker uses a kind of molded copper made from a kind of copper powder instead of a solid copper.
I don’t know if it’s true or not, but we all can see the grainy look on its copper material.
Mine either. I sprayed it with hand sanitizer (alcohol?) and rub with towel paper and the coat is gone.
Thanks. I’m not a tech-savvy and I’m unable to write review in technical manner, so I tried my best to write based on my own experience.
Thanks Bob, I’m going to purchase IMR 18350 to get the most of this flashlight.
I bought the 18650 extension tube for mine so that I have the option of using an unprotected 18650. The tube is a little narrow and won’t take my protected KeepPower batteries.
It is a great option to have for those times when you want longer run times.
http://www.banggood.com/Astrolux-S41-Astrolux-S1-LED-Flashlight-18650-Body-Tube-p-1054468.html
Thanks for the informative review.
