Warning KD Black stars, de-doming a couple XHP35HD E2-1A’s in racing fuel, and the substrate is lifting, guess I have a couple more 20mm copper spacers!
I did not try any triples, very happy with the Noctigon ones. I will have to watch them when removing domes, I always solder the led on before I soak them to remove the dome. Have not tried any of these in gasoline.
I hope that KD can get the new XP-L2-W2 LED´s until the BLF Q8 is ready to be sold.
This will be a lot of work and also not realy cheap but well worth. The Q8 + 4 new XP-L2-W2, a new XHP50.2 as upgrade for my modded TN31 (K40M driver with resistor mod and dedomed MT-G2 LED and i added a lot of copper to help with the extra heat), and a XP-L2-W2 upgrade for my UF-1504.
@djozz would it be better to reduce the current to 500-600mA/die? If all dies get 700mA the LED gets a total of 2,8A. I think that this could get really warm without extra effort regarding cooling.
The full 1a per die may be a bit much if all are on at the same time. But then again, if it were me I would find a way to use the full power Can you add some cooling fins or added heatsink to your aluminum profile?
Edit: Actually I see that 700ma is the max rated current for these dies. I don’t think I would top that especially without a direct path mcpcb.
Finges I am currently working on a Narsil FET+7+1*7135 driver set up with thermal management
If the Narsil works out great I will have a spare H03 driver
The H03 one has too high voltage drops as the current has to go through the inductor and a small transistor @3A the losses on the Skilhunt driver are 410mV, so a fresh 18650Q cell can reach 3A only with both springs bypassed for a short amount of time
And I dont like the timed stepdown
The UI is OK
An Attiny13A 7135*8 driver with eswitch firmware is also an option, but not priorized atm
You could get a XHP50 with boost driver in there, but I see thermal issues.
I have never ordered from them... Just found some tail switches I need badly and signed up ready to place my order and it says account not activated...
Anybody know a US vendor with 12mm*8mm*8mm for sk68's. Ordering from anywhere else just ain't working tonight for some reason.
It was around 4:00am my time when I posted that and it is not 9:00am that's 5 hours for a conformation email.
You guys may be the best on the internet, I have no idea as I have never made a purchase from you. I know for sure that you have in stock parts that I need.
Problem is that everything we do like you making a sale and me making a purchase. All of that is handled through your server and for some reason it is really bad at sending out an email to activate my account,
The last thing I would allow in my store is anything that would keep my customers from making a purchase. I will talk with some of the senior members as they will know you. I will ask their experience with you and make a decision then.
But I am not going to email customer service in order to become a customer. I shouldn't be working to purchase from you, you should be working to earn my business.
Sorry if that sounds cold. If it makes you feel better. Amazon they love my wife, and they really hate me.
