Great post. It will be very useful to new newcomers.
Try this:
If that worked on your browser, just quote this message, select everything between and including the angle brackets, paste it somewhere like Notepad and replace the URLs with your own (be sure to get the whole URL but just the URL, leave the punctuation alone) and Preview the post as many times as you need to test it. You can always quote this message again to start over.
This gives you mouseover and onclick actions so you can add depth. Everything but the onclick should be some compatible image. You won’t win any friends putting an HTML link in a mouseover. But the onclick is what that’s for anyway. Remember to specify your Width, no more than 100%, please.
Thanks Dimbo!! That worked great, and so easy! Here’s mine:
I also found this code for inserting a GIF:
(click quote to view or copy code, just swap in your own image address)
hmm…never fought,i will get problem with this:)) how can i post pic from my computer here please?:laughing:
please add the following css rule for images as they break zooming on mobiles and also looks bad on desktop if the width is below a certain value. thanks
.forum-post-content img {
max-width: 100%;
I can't seem to post pix.
Having been in this situation just last weekend, I’m hoping I can help you TKCUSN. What picture hosting website are you using?
Thank you for your help, but someone else beat ya to it. I have it now. I use Photobucket. You guys are all so nice.
I am in the same boat, using photobucket but can not post. i am guessing that directions for the new forum software are in here somewhere. can anyone help me? the pics are fairly high definition.
ken
In the tool bar above the comment input box is a sunset icon. Click that and copy the direct link from photobucket. Please set relative width to 100% or less to keep the image within the thread boundary. Otherwise, every other post is shrunk to accommodate any that are outsized, really annoying.
many thanks to Rufusbduck for the advice, the trick was to click on the photobucket image and then select the url, pretty simple. aren’t they always.
ken
Garry im trying to add one simple picture from photobucket and it is just showing a little tiny greenish square….
I’m not seeing any kind of tree thing for the advanced options. Am i missing something?
The tree is a CPF thing. Here, SB uses the sunset icon button. Click on that to open the image drop down box, then go to photobucket and click on “i ” for the image you want to link and copy the direct link into the image drop down box. Don’t forget to set image width to 100% or less, it constrains images to normal post width. Larger images don’t make screens any wider, they just shrink all normal width posts.
Ok I’ll try that thank you
For those folks using Photobucket…
Beware that Photobucket throttles the bandwidth for 3rd party hosting (which is what you are doing if you link your Photobucket image). If you happen to have a popular post (a review for example), then you may find that folks cannot see the images due to your account exceeding it’s free 3rd party hosting bandwidth allocation for free accounts.
See for FAQ from Photobucket here
I’ve seen several posts recently where the pictures cannot be seen due to Photobucket bandwidth restrictions.
I started using Imgur due to this limitation. But it looks like Imgur doesn’t allow direct linking to images using the BLF method. You have to use their Embed link (copy and paste) which inserts the image with a little Imgur frame around it. Not as clean as Photobucket, but you don’t have the bandwidth restrictions for a free account.
It seems like you don’t know how to use imgur…
Here is what you do:
- right click image
- click “open in new tab”
- copy the URL
- click the “insert image” icon on BLF
- paste the URL
BTW photobucket is a disgusting adware and malware cluttered site, nobody should use it anymore.
EDIT-
You can also right click -> copy image address instead of opening in new tab and copying the URL, OR you can just copy the “Direct Link”
Thanks Enderman.
I was using the unregistered mode on Imgur and it doesn’t have the same interface you show. There is no convenient button to copy the direct link to the image jpg. However, the right click method does work to get the direct URL to the .jpg
Thanks
You’re welcome.
Can you even upload images to it in unregistered mode??
I don’t think you can…
