Hhmm, I dunno then. Sounds like it's PWM related. Have you tried an alternate firmware? Which firmware are you using? Might be something like a bad 7135 or solder joint, but if it happens on multiple boards, probably not. Could be issues maybe with FAST mode PWM's, or just the higher clock rates of PWM. This board uses a lot of 7135's, so many borderline spike/noise issues are amplified to a point of a problem. That typical D1/C1/R1/R2 circuit design barely gets by with 13A's. In fact I believe the spikes are out of spec with the 13A, just that the 13A tolerates them better than the 25/45/85's.
I think i have tried only this STAR_Momentary firmware:
7135’s have been those from Fasttech 100pcs packs, so far these “Raptor Claws”.
I have tried both FAST and PHASE PWM, made no difference. Clock rate i have not touched, maybe need to try that too.
Also i’m not 100% sure if it behaves like this with batteries, i don’t remember whether i tried or not. I test these with lab power (Manson HCS-3302) before putting in host. I did read for a long time ago about this C1 misplacing and i just moved it and it seems to work. But now that i saw this DEL’s way to do this, i started to think if i’m doing something wrong.
Hhmm. Not much choice out there for pure 7135 SRK drivers though. HQ, TA, and DEL all have good SRK designs, but think all use a FET.
HQ's boards here: https://budgetlightforum.com/t/-/40540
For the SRK driver:
+1 what Tom said about the small resistor. Replace D1 with a series combination of a 2 to 10 ohm resistor and the original D1, then you should be good to go.
I do have a 16x 7135 driver board on OSH, shared and ordered, but it only shipped yesterday. It should be good though.
Ok, thank you very much for confirmation, i’ll try that next time.
For FET driver, isn’t it “direct drive” with PWM value of 255? I think that could be only option for ~3-4pcs of XML2 in SRK, for more leds that will make so much current for such small host and with modern batteries that could give so much current still keeping voltage high. With these 7135’s i can control current much easier. Or am i missing something here?
Strange you're having issues with that driver. Yes, it is the "old configuration" with the capacitor after the diode, but I have built and sold hundreds of these without experiencing that issue. Tom has used them as well, even souped up if I recall.
Well i have to try next time with batteries before making any changes to make sure it is not failing because of my lab power.
But after moving C1 before D1, it has been working nice. Very good board thanks!
I’m learning how to use Eagle now and i was thinking to try draw SRK board with 3-4 7135’s groups so i could use without PWM, or maybe one 7135 with PWM, for best efficiency. Is there really sense, maybe not. After that there is ofcourse problem with firmware, don’t know if someone has done that already.
You might check out some of the new triple channel drivers and firmware before designing your own Oshpark board.
Sure, i tried to search but couldn’t find any triple channels, can you point me where i could find some?
Still i would like to learn Eagle (and better coding), have to try something and order and see what made.
I don’t know how i didn’t saw that there was really three channels used in that code and pcb, but yes, there really is. Have to say this looks really awesome, Texas_Ace has done really huge work for this driver!
4 parallel 18650 battery plates. I’ve searched and cant find anything. does anyone know if they exist or even a battery carrier the ends can be robbed from? This is for the Ol comp light build.
Steve - Can you salvage them from a cheap SRK? Might be cheaper overall.
Thanks Tom. I would if I had one. Wonder what the cheapest 4 cell torch out there is?
Think about $14 US. Let me check my order history in Ali...
here it is: https://www.aliexpress.com/item/High-Power-3t6-LED-Flashlight-Torch-3-14t6-3-x-XM-L-T6-34000-LM
OSHPARK says there must be a 15 mil clearing between traces and outline. Shouldn’t this also affect the ground ring on our flashlight drivers? I have checked a couple of board designs from forum members and have NOT seen this clearance anywhere. Isn’t oshpark that strikt with its design rules, or did they correct the gerbers or what else?
It is hit and miss, sometimes they cut the copper back from the edge of the ground ring and sometimes not. I always have it extend to the edge and if they cut it back, so be it.
On driver that are really tight you can oversize the pcb and sand it back to make sure there is copper to the edge.
Thanks. I’’m working on a Q8 driver currently and actually there is a tight fit from tube to board, so I think I have to do oversizing and sanding.
Btw I also had a look at some of your drivers and noticed you use a clearing of only 8 mil between ground pour and other signals. Have you ever experienced faulty boards because of this or did they all work out ok? And - as far as I could see - you don’t enable thermals for your ground pour - is soldering still easily doable without thermals?
I use whatever the specs on oshpark are as the tolerances on my drivers, unless they changed recently that is. I always run the clearance test to make sure everything clears before releasing a driver. Never had an issue yet.
All my drivers are setup to be hot air reflowed, so the whole driver is heated and reflowed at once. In this case the thermal setup of the driver doesn’t effect the soldering a lot. Never tried it with an iron nor would I even try to do such a thing to be honest.
That’s good to know, thanks again.
