PS: if you don’t see the right flash sale price, please clear the browser cache or add product to cart to try ( suggest add product to cart, now it’s the fastest way to judge if the flash sale is still avaible), final price should be subject to the order price, as for some very limited quantities flash sale, it goes fast before you place the order )
coupon: TYOS ( 10% off discount from full price when not at sales, every one could use more than one times )
coupon: OUT15OFF( 15% off discount from full price when not at sales, only for new users )
Hi GB, could you find some way for shipping batteries to Serbia? I am literally left without options for ordering batteries. On Ali some sellers are using Turkey post but I have no trust in Aliexpress for batteries… Can you consider using Turkey post?
You are invited to Gearbest Epic Lights Sales, and we improved” the subpage”:http://www.gearbest.com/m-promotion-active-282.html for coupon copy usage, have your click here, hope you will like these outdoor & survival gears.
The spring wakes us, Deals come frequently and regularly.
Light up Spring, Bright Make over Ideas: http://www.gearbest.com/promotion-world-of-light-special-1069.html
We here to introduce about 76 Deals in such Lights collection subpage:
indoor lights, Bulbs, Strips,Smart Lighting, outdoor lighting Gears,
Laser pointer, Stage lighting, Wall lights and Pendent lights.
Check and find some different than ever before.
Can you please have a look at my ticket T17033106379.
I bought a Brother 1602 (item 208237501) and the knife I received is defective from the factory.
The knife has no detente at all and therefore has nothing holding the blade in place when in the closed position.
This makes the knife unusable and actually dangerous.
I disassembled it to see what was wrong and the detente hole was drilled too wide so the detente ball sit at the bottom of the lock bar instead of being raised and doing its job of keeping the blade secure in the closed position.
I opened a ticket and provided the video and photo below and after a whole 2 weeks, your customer service determined that there is nothing wrong with the knife and are offering 50 GB points which is unacceptable!
Can you please look into this and get a replacement of a knife that is not defective sent to me asap?
Wow, that’s ridiculous! What a horrible customer service. I certainly won’t be purchasing from Gearbest until I hear they’re fixed your issue.
Best of luck
Sounds like standard procedure going on (same with Banggood). What seems to work is to stay calm, explain them that you cannot accept their offer. Explain the same thing over again: knife is (too) dangerous to use, and product is not as described or should be etc. It may take some back and forth messaging. I’ve read about these cases regularly, so hopefully you’ll be successful. Good luck.
Thanks guys for the support.
TBH, the only reason I still shop at GB is because of gearbest here on the forum.
I have had a couple of issues last here and the member here made it right both time. We’ll see this time.
But yeah, their regular CS is pretty lame.
@bdpf79, sorry to hear that, we got your ticket number and arranged your order to service center minutes ago, check your email or inbox minutes later, please.
