A lot of ultrafire cells are just junk smaller batteries inside the shell with sand around. Or worn out laptop pulls relabeled best case is old China lab making them. The Chinese labs can only make ICR batteries they don’t have the money to update to the equipment needed for imr inr batteries. Besides quality like plb or etc. Hence why 26650 maxes out around 5200ish. If a top tier company made them could easily see 7000mah. If you google Chinese battery recycling you can see the 55 gallon drums of tens of thousands of batteries piled up waiting to be graded.
I can’t tell either from the pic but it’s a pretty safe bet given the brand. Lots of Amazon/Ebay “protected” cells don’t have any real protection circuit or even vents. They just copy the buzz-words in their product descriptions and inflate the mAh ratings to sell their 18650 pipe bombs. I have one that’s wrapped just like that in a fire proof safe that doesn’t seem so fire proof when the ignition source may be on the inside.
Have you THOROUGHLY vented out the room/area that this happened in? Lithium batteries out-gas hydrofluoric acid (HFA) which is extremely toxic even in small amounts. Inhaled HFA has no immediate side-effect or pain but you could have delayed onset symptoms days or weeks later. Florine toxicity is very serious and can have long-term or permanent consequences. I would stay out of that room and keep all windows open for a minimum of 24 hours, potentially get everyone out of the entire house, personally. Be on the lookout for any strange symptoms over the next couple weeks - this includes headaches, nausea, vomiting, dizziness, mood changes, tinnitus, neuropathy, etc. If you have any symptoms, go to a doctor immediately and let them know you have been exposed to HFA.
That shape at the left end of the cell often indicates a PCB which is the protection circuit.
It probably doesn’t have an actual protection circuit, but clearly something is there.
I’m glad this turned out with a good ending Zebretta. :+1: …
And I am sure you know it by now….
………….but everything anyone needs to know about these batteries are contained in the picture you took.
The name & the mAh rating………
“CrapFires” are just that……… crap. And no 18650 battery has that mAh rating… that is crap too.
About the only thing I know of with “Fire” in the name that can be trusted is “WindyFire” & I can only speak of their 14500 Red ones. Cause that is the only ones of those I have.
Glad you are ok.That is the most important thing. :+1:
I think we all know this and most would agree w/ this but I will repeat it!
The odds of that happening w/ a QUALITY battery[Samsung/Sanyo/LF/Sony/Panasonic] are a lot less.
I wouldn’t use a “Pick ur Fire” battery if you paid me or gave me ones for free!
The Only “fire” I used is Windyfire IMR 14500 That HKJ reviewed.Besides the aforementioned, I never used a Surefire but that would be the only other “Fire” that is a quality battery.
I still can not comprehend why someone would use these batteries just to save a few dollars when the performance is sub par and the risks of an accident increase. :person_facepalming:
The only fire batteries I trust is thorfire. The 5000mah 26650 tested out good. Good to about 10amps before major sag.
And from people on here unwrapping the 18650s they are a Samsung rewrap.
I’ve heard windyfire mentioned before but don’t have any experience with them
In the end at least you were there to notice the smell and move it. It maybe have been a old grade c rewrap. It didn’t go into thermal runaway. Which newer name brand cells won’t do until about 450 degrees. Did it vent is there any residue by the top. I mean visually don’t touch if there’s residue I imagine is highly toxic
Edit,
Wanted to add if this was a protected cell it would have done the same thing because a protection circuit isn’t going to be able to stop a internally caused short. If its in a flashlight or charger its going between the circuits and the PCB can trip and cut the current. So don’t get a false security about protected cells. Just make sure the underlying cell is a name brand cell
I still have 4 X 18650 Cytac cells. HKJ reviewed them. Although the cell is Unknown he stated it acts just like a Panasonic and rated it a very good cell.
HKJ:These batteries uses a undisclosed cell, that works exactly like a Panasonic cell, i.e. it is very good.
I’d guess that most Li-ion cells sold are put in laptop computers or power tools, and I haven’t noticed stories of power tools burning houses down. Vape devices are almost certainly a bigger market than flashlights.
Very small I’d say, or we’d hear a lot more about it, (considering laptops and power tools) but if you are the one in ten thousand per year (or whatever) and it’s burned down your place, that’s not much comfort.
I’d guess that a part of this is that laptops and power tools use new cells and have protection circuitry, whereas *fire 10,000 mAh 18650 cells are clapped out, recovered rubbish. I think a part of that is that considering most users of flashlights, you can get away with palming off an originally 2,500 mAh, now 750 mAh cell, as OK, but that wouldn’t fly with vape devices, laptops or power tools.
The thing I find worrying was that it was just sitting there and decided to go off. You weren’t charging it or using it.
Actually this is a point of interest. HKJ tests performance of cells, but what do we know about how safe these cells are? For example, if we look at the 30Q’s datasheet: https://www.nkon.nl/sk/k/30q.pdf
On pages 14-16 test results are shown for short circuit test, high temperature (140 degrees C) test, and impact test. And what do we know about the differences between a branded cell and an unbranded cell if you drop them on concrete? Of course don’t drop them in the first place, but is the branded cell safer in that respect?
So you see, since I don’t know the answer to these questions, at this moment I prefer to play it safe and stick with branded cells when possible.
I agree to use the Top 5 manufacturers as I mentioned in my first post in this thread.
As far as these Cytacs go I have had them 3 years,…like I said I have no worries about them.It probably is a Panasonic cell or at least One that is of good quality like a Panny cell!
P.S. You did not include part of my post where I mentioned what HKJ said and you also left out his quote!!!
Here it is again!
Gotta say, the way that battery’s bulging, this is begging for a yootoob video of someone with a .50BMG putting a big big hole right through it to see what happens.
The number of people who don’t know better VASTLY outnumbers those who do. That’s why so many are sold on ebay. I really didn’t know better until I came to these forums and started reading. It’s surprising there aren’t a lot more incidents. This really caught me by surprise. I hadn’t charged the battery, discharged it or anything recently…it was just sitting there and decided to go thermal all by itself. Scary is a good term.
Yes correct, I should elaborate! Well the thing is that you have performance as in voltage sag, and the max amount of current you can run, and the max temperature it reaches. These parameters form the performance of the cell I think. And this is what HKJ tests.
I’m not too sure whether he means that a Panasonic cell is used in the Cytac, or whether the performance as described above is similar to a Panasonic. If the latter is the case, then I become weary regarding safety parameters as mentioned in my previous post. So basically, the question is what HKJ means with “that works exactly like a Panasonic cell”. Is my reply ok?
I’ve never had it happen so I find this a bit disturbing too. It could happen while sleeping. And that FHL thing mentioned above…wow.
But….it’s not the first time I’ve ever smelled a burning odor and never found anything. Now I wonder if that could possibly have been a battery self terminating but didn’t go nuclear?
