DEAL ENDED - DX XM-LT6 900-Lumen 5-Mode White LED Flashlight - Titanium Color (2x18650) - $29.99 (Normally $41.30)
I just tested it at night and... I like it, and very much.
Even standard-stock, it is awesome and better if you consider the price.
I said it was cheap because of some small imperfections before the anodizing, and also at the tail I had to remove some aluminium... But it is OK anyway, not the best, not the worst.
Can'tWaitForMyDriverToArriveFX-32
yeah, mine had a big, and strange, chip/burr at one of the lanyard holes, and it was completely anodized lol
hardly touched it and it fell off.
I should have taken a picture. I couldn't figure out how they made it. It was like a donut. maybe they drill a pilot hole then hog it out to size real fast.
When the finish gets beat up I'm going to strip the anodizing and shot peen it. might not even wait for that...
I've finished shimming the collar w/ copper. Easy mod if you have the right size sheet. I'll do some pictures at some point, the epoxy is setting...
I'm not as into throwers as most of you guys are...so I'm not sure what to make of this photo.
It looks like it really stomps the BC40 (which I'm assuming is stock) - but I have no idea what reputation the BC40 has...
It's simple a good quality and cheap flashlight ($40 from DD with coupon) with good balance of flood-throw, overall nothing special.
A common UltraFire C8 xm-l has almost the same ability as BC40, but the quality difference is significant. Plus you get a lot of spare o-rings + a holster with bc40.
here is a comparison C8 mouse out, bc40 over
C8 has a little better throw ability (when the battery is full)
very helpful, thanks for taking the time to post that.
I don't own a jetbeam, yet, but I imagine they're much higher quality than this thing.
I tend to have "whiskey taste on a beer wallet" :)
I'm sharing some pictures with you; they were taken under a tree because there are around 100°Fahrenheit now.
-CLICK TO ENLARGE-
Gallery link: http://postimage.org/gallery/bejpcyha/
nice pics :)
Meanwhile, I measured the led current (with the modified driver) , and got only 3.2A. In this case, the driver efficiency is somewhere 72%. But something wrong with this, because I tried out the reflector with an another led which was powered directly from a lab power supply, and around 4A got the same 53000cd. That's interesting, maybe the DMM self resistance, or the PWM output ditsurbed the measurment.
...and I did a new modification. Now, if I turn off the light and wait about 5sec and turn on, it will start in Hi mode in any case.
How did you did such mod? Modes in this flashlight sucks, when I turn off, next time I turn on it starts in the next mode, and not the last used.
I have to say that, if anybody wants to make a review of this flashlight here at BLF, you can use my pics ;)
a resistor there :) :
You can play the value of the resistor. I used a 30kohm, but if you put a higher resistance, for example 100kohm, the time will increase to about 10sec.
This is how mine behaved stock (might have been a few seconds longer than 5).
But I !@#%@#^!@#$%^ cooked my driver yesterday. Not exactly sure how, probably too much heat from soldering gun (small iron is broken and stupidly used 140W automotive one).
Hearing that it was inefficient makes me feel just a bit better about it.
That was 5 minutes in my case.
Bad to hear that. 140W is a little strong. :)
I think my current measurment was inaccurate so the efficiency is higher than 72%.
actually, I misremembered that from when I had a weller - it is 150/230W!
http://www.sears.com/craftsman-solder-gun-150-230-watt/p-00954046000P
great for most stuff - goes cold to hot in under a minute - not so great for circuits.
Well, additional info: Stock driver pulls 2.70Amps to the LED, in my case with two fresh charged 18700 XTAR.
Don't know why the SST-50 driver takes so long, I ordered both things at same time! Both with Tracking N°.
I wish the $20 one was the same - 55.87mm head versus 58mm, as well as fewer fins.
If anyone has an extra one they would like to sell or barter for, please let me know.
I'm starting to realize why you guys joke about the xxxfire lottery. There is one small imperfection in my reflector, but otherwise, no build quality issues with mine.
I ordered the sst-50 driver on Dec. 8th. They shipped it Jan 8th.
Anyway, it won't fit the pill, or at least it will require a serious mod. I will do it if I can't find one that fits. I want at least 4A but not more than 4.5. The light will just be used for 'wow' and brief long distance searching, otherwise I would consider that a big waste of battery capacity.
I've ordered this for testing. http://kaidomain.com/product/details.S009442
aqualab driver db says a user reported 3.3A but doesn't sound like it was heatsinked. KD says 5A.
So far I have resisted stripping the ano but if I like what I end up with I will strip it. I've done some informal experimenting w/ bare and anodized aluminum and a torch. I think ano holds in a lot of heat. Flaw in my experiment...measuring by touch - it might not make much difference w/ air as the sink.
Truthfully though, I just don't like it much. Give me silver, black, a color, and in shiny or matte, but this is just kind of weird...
Sorry Chicago-X, I'd been watching price on every version of this torch for awhile:) The manafont one looks pretty good.
If this ends up an (exceptional) performer I might buy this one.
HAIII and 4.3A
http://www.cnqualitygoods.com/goods.php?id=1185
no group pricing but I bet he'd be happy to do some
edit: but...i guess if you're thinking multi emitter mod, you'd want the cheapest option...
dthrckt, Ric said he only has 1 last piece for the On The Road X6. That piece is flawless.
I have the OTR X5, it definitely does not feel like it's a budget light. More of Solarforce M8 / Dereelight.
Thanks for the heads up.
That's unfortunate, since I've already spent about $300 in the last 3 weeks (on this stuff alone). I know...just average for you:)
I've been watching that page for quite awhile, hoping I'd snipe one (...it!) if the price dropped a little.
Actually it has dropped, from $65 and now to 59. But i don't dig SST-50s.
I did notice that last night - so tempted, but yeah, the price is really ~72 because I'd swap the emitter right off. I guess I could ebay the sst-50.
_____
the driver is as wide and tall as the pill
dx sku 13619 (59mm mentioned above) and 13569, 66mm
much more dome and much less edge on 66mm
it also has a shorter focal length than the other, and does make a good image of emitter, albeit w/ a substantial corona.
the focal length is so close to d1 emitter distance when placed on directly on reflector that I would have to rig some kind of holder (so as not to use reflector) to determine the exact best distance.
But, it is unfortunately significantly too wide. You would have to remove more of the dome than viffer did here https://budgetlightforum.com/t/-/5182#comment-98081
I get 2x the lux w/ just the reflector than w/ both (visually and on meter), and although the beam would look better, I can't see how not using the reflector would increase reading (w/ only lens).
But, I will eventually find a host for this lens - it should be very impressive.
avoid the 59mm sku 13619, this is my second sample and both make multiple scattered emitter images at focal length. maybe Ok for just tightening a beam, but not full throw.
