Still nothing received from KD though...Ahhh cHristmas times make shipping time quite high....
Im using magnets on my plus side, what risk am I taking buoying doing this?
Just a couple more thoughts/observations:
Nice build quality
Bad PWM
One cell operation - it looks like it goes DD (which I think is what we expected) - 4A on a single KK 26650, 1.6A on an A123 (3.2v) cell
Heatsinking seems good, but I haven't REALLY put the screws to it yet.
Could you please test if 2 x 26650 works?
In general? Yes. 2 x King Kongs out of the package? No.
The positive "button" on the KK is the problem. It actually sits lower than the shrinkwrap on the cell.
LOL
I just took out the light meter and got 24.9kcd (249 lux measured @ 10m).
(the cells were not fully charged and the light had been on for about 30 sec.)
tip for extending batteries, for those that don't want to solder, and have magnets
wipe anode and magnet w/ acetone or alcohol, put a thin layer of this on anode, then the magnet and let sit overnight (since it isn't exposed to air).
http://www.amazon.com/CircuitWriterTM-Precision-Pen-silver-based-grams/dp/B0002BBVQO
it is basically conductive adhesive but in a much nicer dispenser than a jar. it costs half as much at radioshack and you could do a few hundred batteries. Store it tip down or the tip dries and clogs.
I guess i'll just solder mine then, seems like the easiest way to achieve a reliable solution..
Still haven't bought a light to use them however. I ordered some king kongs in advance because i was so stocked about the tr-j12 but still haven't pulled the plug...
Bugger about the king kongs
I attacked the positive contact tonight. It turns out that under that nylon retainer with the brass contact in the center is a spring. I took that brass plug out of the nylon retainer and replaced the spring underneath with a longer/larger one. I also drilled out the retainer to make the hole large enough for the new spring to come through. The spring I used is a standard spring from a Solarforce p60 switch or the like.
Connection is greatly improved. King Kongs still didn't work, but I added a solder blob to all of them and now I'm ready to rock and roll.
I'm only seeing a 5% 4% drop in lux from 10 seconds to 10 minutes. :) The heat seems to stay in the head, the body stays pretty cool. That would generally worry me, but looking at the numbers (I know its only 10 minutes), it's looking good.
Did you take a peek at the driver?
I did not. I didn’t want to press my luck on the first day. Functionally, the driver is VERY similar to the one in the TR-3T6, just with more power.
Are you saying my 26650's might explode all of the sudden?
For you and many on this site, it is highly unlikely. For me and some others, we usually do discharge capacity tests (on a hobby charger) on the cells so as to match them for multi-cell operation, in addition to voltage checks everytime we pop them cells into the light. And remember, you choose/alternate between 2 or 3 cell operation, so you need to check. 2 cells might be at 3.9V simply because you used them for 10 mins before, and the 3rd might be 4.09V.
The thing is, folks are selling such lights on Ebay with grey trustfires, blue ultrafires, and some even noname blue Chinese LiCo. One cell might have 1500mAh worth of juice, another just 900mAh. How not to expect an explosion?
2 cells are like 3.3A? That is no joke.
Google reverse charging too....
You can prevent a lot of incidents with just a protection circuit.
But not to worry, it is highly unlikely, but every multi-cell light esp 3 cells, i feel there must be a warning.
I set out to do a runtime test, but I just got too nervous 20 minutes in. It had dropped about 8% but the head was very hot. I just had it tailstanding with no extra cooling. At the 20 minute mark I started using a hairdryer with no heat to blow on it for a minute or so out of every five. I could get the output to get back about half of that 8%. After a blowdrying session, i tried holding the light in hand for 5 minutes and the output only dropped a fraction of a percent.
The additional cooling was evident in the output within 10 seconds, leading me to believe the emitters are very well heatsinked and the head has a good thermal path.
I could use a fan for the runtime test, but I don't know about you, but I don't have an EDC fan (or hairdryer) and I'm surely not going to hold the light for 2 hours (EDIT: 1:30 - the cells wouldn't last 2 hours), so I'm going to assume it will run for that long provided I can keep it reasonably cool.
All things considered thats pretty impressive. I wish this one had a "turbo" mode like the DRY as it seems it would handle the heat much better. On second thought screw the "turbo", I would be happy for 3A per emitter.
Mitro, 4% for 10 mins is really good. I think you have slightly lower temps than my case, that is definitely in the league of the Uniqurefire 3900 modded with foil and the Trustfire TF-3T6.
25k cd is good too, that is like the DRY in Turbo mode.
Actually my J12 at this moment is already being delivered, but nobody is at home to receive it. So need to collect it tomorrow from the PO and only test tomorrow night....but i guess i'll bring some 18650s and the DMM to play in the office.
So the S1 and J12 will be going to Indonesia soon next week for a full workout. LOL!
I ran the light for most of an hour and at any time i could blow on it and get it within 4 or 5 percent of the 10 second reading. Also, the medium is about 65% brightness, so you can still get massive output with a decent bump in runtime.
Yes mitro, the idea of such 3x and 5x XM-Ls is to get massive light output and still be able to do long runtimes without the issue of overheating.
To give people an idea on the big picture, some folks already encountered a kick down from Turbo to high in the Nitecore TM11 before 10 minutes, with this light just trailing a wee wee bit in OTF output possibly. Yes they are definitely not equal, but just a frame of reference.
59 deg C stable, before kickdown.
Sorry for so many posts, but I forgot to mention that I even fired it up on 4 C alkalines. 4Cs and a little spacer at the back means that even those who like NiMH can benefit from this light. :)
I'd like to know if it can take 4x li-on, but I'm not about to find out. :p
EDIT: I tried 4 x AA Duraloops and got a 3.3A draw to start and about 75% of the brightness of 3x li-ons. Not too shabby. Also, there is no difference in brightness (less than 0.5%) between 3 fully charged 26650 and 2 fully charged 26650s.
