Yes I mean the flashlight gets hotter to the touch, and quicker, even in medium mode. So yes, those cells are well used, I will not use them in the summer for sure
that means these cells are better than your others.
measure your tailcap current.bet its higher.
this is a good thing.they are not well used they are better.
Will have to try that
Hadn’t seen anything in weeks but then 2 in one day
Lenovo Thinkpad 45N1001 6 Red w blue top SANYO UR18650FM R1122 (2600 mAh)
Xbox 360 controller battery pack with 2 NIMH Sanyo AA’s (2100 mAh)
WOW!!!
I didn’t even know that 7.5Ah EGO battery existed.
Would you mind posting your find in my thread? I started it when I first found a Ryobi 40V 2-1/2 years ago. At the time I thought THAT was unbelievable.
Look what I found in the recycle bin
You definitely have found the best all time battery as far as I am concerned!
That battery can be ordered at Home Depot and costs a lot of money.
Good seeing people doing sort of the same thing I’m doing…
I’ve had moderate success with taking apart some laptop batteries. I’m mostly buying cheap Chinese knockoff packs which actually aren’t as bad as you think. From my 4 different suppliers on ebay, every Chinese cell has managed to get me at least 2000mAh with a 1A draw. Lowest and cheapest cells which when I hit them on the ground, sound like they’re partially hollow and have another battery inside, achieve over 2000mAh no problem. So that’s kinda strange. Weigh in at 41g and my other suppliers weigh in at 45g which is on part to other brands. I’m actually in the process of using these to build an ebike. 91 cell 48V battery should let me stay under 2.5A per cell so I should have plenty of power and no crazy power draw or anything like that…
Hey Philaphlous, I have been wanting to make an extra battery pack for my 48v ebike. Just curious what method are you planning on using for putting the cells together? Im leaning towards carefully soldering them instead of using a spot welder. Theres a guy on youtube that uses a freeze spray to cool down the cell after soldering or spot welding. My battery pack I bought with my ebike kit has 52 cells but I bet 91 cells will get killer range.
I just picked up a 60w soldering iron. Tested it last night…gosh got it way too hot, apparently it has a temp controller, whops. The 60/40 solder was charring it was getting so hot. lol. I found someone on endless sphere that used 3.5mm solder wick as the main voltage lines for the cells so I’m going that route. I hope 10ft of that stuff is enough for 91 cells. I’m pulling either old laptop battery packs or new cheap Chinese packs out and spreading the brand name with the chinese cells to try and even out the voltage sag because I’m sure I’m going to get that. Hopefully I can keep each of the 13 banks balanced or else its going to take like days for my BMS to balance everything. lol…
I might chill my batteries before I solder them but I’ve read that thermal shock also degrades cells so I’m not sure yet. I have a 120mm computer fan to evac the soldering fumes…
It’s going to take forever to put it together but I think I have a great design. I’ll post my build on here once I have everything. Still 1-2 weeks out for my BMS. My battery isn’t the most robust and I’m going to have to keep my wattage under 800w draw. <3A per cell.
Ive read so many conflicting things on what degrades the cells I just feel like if I can get free cells from laptop pulls and get only 100 or even 50 cycles Id be happy just because I made it and it works. Of course, I dont want a fire either. I also came across an interesting video on youtube about not using a bms at all would be beneficial by using a balance charger here:
Im considering going this route but those balance chargers are kinda pricey.
Anyways, I have never tried going to home depot to check the recycling for batteries. I think I might try sometime this week.
I haven’t gone quite that far to check HD or any other place for old cells but I did pick up a few used laptop packs off ebay. Moderate success. LG cells get me about 2200-2400mAh while the other LG cells get only about 1400mAh and the Samsung cells were completely bad with only about 200mAh usable.
Yea its about $1.5/cell for the 2000mAh Chinese cells but they’re consistent in their voltage drops, capacity, and I know they haven’t seen either extreme loads or heat that could potentially damage the cells. I’m hoping that my commute won’t fully drain the battery pack as my charger is only a 2.5A 48V charger so that’ll take forever to recharge plus I hope to keep the discharge depth to a minimum. I’m in-between jobs right now and so once I nail down a new job I’ll go full steam ahead on this idea. I may be moving, may live closer to my work, may end up absolutely needing to bike to work with outrageous parking prices…who knows right now…
Well I wish you the best of luck with the job hunting. I actually sold my car and got an ebike kit so I can do the 2 mile commute to and from work. Its working out great so far however the weather forecast is showing 105 degrees on Wednesday so that might make me regret my decision. Well see.
Oh yea! Broke open a genuine Dell and genuine lenovo laptop battery pack. The dell came with LGDBB31865. Charging one up to test the capacity. ALSO, wait for it! Panasonic NCR18650D cells! 2700mAh cells. woohoo! All 3.6-3.83V which means they’re all good! Testing out the Chinese cells again. Just realized my imax B6 is recording the voltages pretty far under what the cell is currently at. I’m using both a multimeter and the Imax. Imax says 3.56V right now and multimeter on the cell says 3.71V…dang… Definitely more capacity in these cells than I think. Now after this run I’ll test the 1A draw to make sure its really 1A or else I’m screwed…lol
either you have a fake b6 or a lot of resistance in the leads/holder.
maybe both.
aftermarket pack for my alienware m17x r3.
no model number.
was doa. no lights when pushing the test button.
red x in windows.
9 grey bak 2600.
all checked around 2700@1a.
ir 45mohm.
hp mu06 generic.
died after 1 cycle.
another recycle it and we send replacement.
twist.pop! crunch!
and we have 6 red yik lik 2200.
all at 3.95v
near 2300@1a
HP MU06 = 6 Green Samsung ICR18650-22FU (3.7V 2200mAh)
another m17x r3 pack.
original 90wh.
damaged by lightning.
took mobo,power supply,battery.
customer had me repair it and left the killed parts.
9 samsung 28a.lilac/light purple.
all like new.average so far 2580@1a 4.2v.
these are 4.35v cells.
lb1 “high performance”
replacement for alienware m17x r4.
came with machine when i got it so unsure of age.
would not give me anything with batteryinfoveiw.
and “high performance” is a joke.this is a 6600mah pack.
the stock is 8400.
the joke continues…
thermal sensor wadded up behind board not in contact with any cell.
brittle case that crumbled with no effort when i disassembled pack.
one drop would have meant big problems.
no tape anywhere on the cells.
plenty of opportunity for strapping to dig into cell sleeves and short.
and cause of death?
wire MISSING from a cell tap to board.
this pack was stillborn!
so add no qc to the list of ills.
the good?
9 dlg n18650 at shipping voltage.
i suspect they are as new.
all 9 at exactly 3.51v.
decent cells for most flashlights.
Found a few Makita 18V power packs - water damage or corrosion on several cells. Easy enough to disassemble but only 4 - 6 potentially useful cells, If those don’t pass testing then about all I’ll get from this “pull” is the dividers for cell storage and some insulator disks.
Dell PC764 = 6 Green Panasonic CGR18650EA (3.7V 2550mAh)
