PALIGHT T50 10W L2 1000LM 26650 Outdoor LED Flashlight with included 26650 battery is for $22 using f188d6 coupon. Free registered shipping included
UPDATE: Deal Expired. » Coupon code available here «
Lumintop ED25 XM-L2 620LM AA 6-mode Tactical Outdoor LED Flashlight is currently for $18.70 and BG points are working so the price can be lowered further even below $15:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$15.90 |
$17.71 |
$15.52 |
$15.33 |
$14.96 |
Holster included.
Deal at $6.95 expired. » Coupon code available here «
Use this link: Nitecore Tube to get $6.95 price. No coupon so you can use BG points to drop price even further:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$5.91 |
$5.84 |
$5.77 |
$5.70 |
$5.56 |
New colors are still under restocking though
Deal expired. » New deal here «
LUMINTOP LM34C Micro-USB18650 Protected Rechargeable Li-ion Battery for $7.99
It’s easiest way to convert flashlight into micro USB rechargeable one. Internally it uses Panasonic NCR18650B 3400mAh cell and is longer like all protected cells at 70.7mm so be sure to check if it will fit.
BG points are working so price can be dropped to:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$6.79 |
$6.71 |
$6.63 |
$6.55 |
$6.39 |
Deal expired - coupon now available - ” » details here « “:✜Banggood deals≫ NC TUP ⚡Rofis TC1⚡$23.06⚡S41S ★★★ $34.65 BLF GT mini ★ ⚡ Fitorch P25 QUAD LED 26350⚡X1R angle light ★BLF GT70★ - #82 by petemer
HaikeLite MT01 Trekker XHP50 V2 CW/5000K NW 2500LM LED Flashlight is now for $42 (CW)/ $43 (NW) in preorder until May 13 2017.
BG points are working so price can be brought down to:
Cool white:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$35.70 |
$35.28 |
$34.86 |
$34.44 |
$33.60 |
Neutral white:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$36.55 |
$36.12 |
$35.69 |
$35.26 |
$34.40 |
Deal expired. Now back at $23.95
XANES KT XP-G3+UV 350LM 3Modes Rechargeable Mini LED Keychain Flashlight ◄ using this link drops price from $23.95 to $16.99 and BG points still work so it’s possible to bring down the price to:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$14.44 |
$14.27 |
$14.10 |
$13.93 |
$13.59 |
Preorder for Shinight Camping Led Tent Lantern 350 Lumens 5 Modes Rechargeable IPX7 Waterproof Flashlight Lamp With Magnetic Base at $9.99. Final price is going to be set at $15.99. Basically it’s compact micro USB rechargeable lantern with replaceable 18650 cell (2300 mAh cell is included) similar to Fenix CL35R but four times cheaper. Points do not work for this one because of lower price right now.
Your link is for Xanes KT…
Fixed that, thanks.
You are welcome my friend
Ordered thank you…
Update: Deal expired. ⪢ Better deal available here ⪡
Update: PRICE DROP to $29.95!
Astrolux S42 4xNichia 219C/XP-G2/XP-G3 A6 2023LM Rechargeable Mini LED Flashlight is for $45.95 $29.95 in preorder and with BG points price can be still lowered:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$25.46 |
$25.16 |
$24.86 |
$24.56 |
$23.96 |
- Free tracked shipping included.
Additional 18650 body tube available here: Astrolux S41/Astrolux S1/BLF A6 LED Flashlight 18650 Body Tube for $3.29 or with BG points for:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$2.80 |
$2.76 |
$2.73 |
$2.70 |
$2.63 |
So, any technical details?
What is the driver size, type and current?
In one line it says ‘High efficiency constant current circuit’, in the other it says A17DD.
Sorry, it seems this release was a complete surprise. AFAIK no one seems to have any more confirmed info at the moment.
Judging from the description it uses standard FET + 1xAMC driver with ToyKeeper firmware like BLF A6 and Astrolux S41 but that’s just an educated guess.
Voltage indication using LED under the button could be realized on separate PCB along with USB charging functionality. That’s probably why there’s duplicated voltage level indication using main LED - they did not modify A6 driver at all, just added charger board with side button and LED indicator under button. They already have experience with this driver and probably enough spare units so using that is cheaper and means faster time to market. This would mean the setup is highly modable as the main mode-driver could be simply substituted. But we will not know for sure until somebody will take it apart and do a proper review. Probably that’s also the reason it’s so competitively priced in preorder along with the ability to use BG points to get it even cheaper for loyal customers.
Lumintop Copper Worm And Nichia 110LM Wateproof Keychain LED Flashlight using coupon 2017fnl drops price from $32 to $21.70.
Last 17 pieces left.
how to use BG point to lower the price? I tried to use it, but it shows BG point can not be used for unbeatable price.
There must be some other item in your cart with unbeatable price - it doesn’t have any special designation beside usual orange Promo tag.
Purchase this item in separate order. You can use check marks on the left side of the item to disable it from current order to see which one is causing the problem.
If that’s not the case or you only have one item in your cart try refreshing your cart and/or clearing browser cache and cookies.
XANES 300LM Sensing Headlight Night Fishing Cycling Double Light Source Rechargeable Clip Cap Lamp is in preorder for $5.99. ~150 pcs left at that price. Main LED with reflector seems to be Cree XP-E, there’s also COB LED for diffused light. Package includes headband (not pictured) and apparently 2 USB cables.
IR sensor probably works similar to Boruit IR “sensor” headlamp - i.e. just for switching selected LED on and off. Description does not clarify that aspect.
Battery has standard 2 pin connector (same as used in small drones) and is easily replaceable.
BlitzWolf® BW-LT5 Pro IP68 Waterproof LED Panasonic 3350mAh Powerbank Emergency Camping Lantern with coupon travel is 20% off at $15.19.
Lamp uses single 18650 Panasonic NCR18650B 3400mAh (typical, 3350mAh minimum) cell but it’s not replaceable, it’s USB rechargeable and has ability to charge other devices via standard USB type A female port. It is completely waterproof, white light has two steady modes with up to 75h runtime in low mode + 3 modes red light (2 emergency blinkers + steady red), uses separate blue LED as charge indicator.
Update: deal is back with a price drop!
Hello, you can buy Lumintop Tool CRI Nichia 219B for $9.95 and with BG points price drops further:
VIP0/1 VIP2 VIP3 VIP4 VIP5 $8.46 $8,36 $8,26 $8,16 $7.96
Magnet tailcap for Lumintop tool for $2.99, and using BG points:
VIP0/1 VIP2 VIP3 VIP4 VIP5 $2.54 $2.51 $2.48 $2.45 $2.39 ──────────────────────────────────────────────────────────────────────
Klarus Mi7 Red Blaze using links is for $25.95 expired and can be further drop down using BG points:table(table#posts).
|VIP0/1|VIP2|VIP3|VIP4|VIP5|
|$22.06|$21.80|$21.54|$21.28|$20.76|
Restocking! Any chance of getting this sale again?
