updated: "unbranded Prototype" of UTorch UT03
Martin, please don’t burden our pocket! :smiley:
Man, those reflectors are shallow. Mule type flood almost. I like flood
wall of light…should be a lot cheaper version than nova mm or marauder x7…
like the 2 tone style finishing.
The two tone looks lovely.
The light looks really compact - TN36 style.
The soldering makes me feel happy about myself.
It looks like it’s just going to shout light angrily into the air in a spray and pray kind of fashion. You’ve got to think this is going to be around the 8k lumen mark with just a wall of light.
You’ll burn your hand on the body in no time that’s for sure.
It looks like a fun light to have but it’ll be a battery muncher for sure and they’ll have to have a decent step down on it before you start to cook stuff with it.
utorch, manker, manker, utorch… who knows :smiley:
cant wait to snatch this fat boy for my collection :slight_smile:
Seems great , really compact .
I saw that the head is very poorly made
The reflector is dirty, the solder is not clean, the wire is small(it should be used for 1000 lumen light, not xhp70*3 light)
I wonder why reflector is not OP one.
It’s 12V, so the wires don’t need to be as thick. Industrial facilities are wired for 240V or 480V, often just to lower the cost on copper. That said, I hope that’s a constriction because that would be an easy upgrade.
Even with 12V, it’s nearly 100w, the current is about 8-10A, that’s high for a small wire like that
Reflector reminds me of the Nitecore TM11, where there are also black plastic bits with Nitecore branding on it.
Guys, check out the pic of the UT03 on GearBest’s site (scroll down). It looks like it has MK34’s battery tube (3x18650)…
http://www.gearbest.com/blog/news/utorch-brand-get-premium-flashlights-lighting-808
This post is quite old , it was published when i had the ut01/ut02 groupbuy here .
Aha. Ok. Interesting. I mean back then there was another flirting going on between Utorch and Manker…
will it be two tone color like that?
Nice… Looking forward to further impressions. Some questions…
>How is the PWM?
>How is the parasitic drain?
>Is there a LOTC?
Can you burn yourself when its on turbo :smiley:
OP reflectors give a bigger hotspot. They probably think the hotspot is already big enough due to the shallow reflector shape, plus with 3 emitters your less likely to see a donut hole shape. So SMO, and higher efficiency, is the smart choice.
If you will look at maukka’s tests you will see that most cree leds (and all new multi-dies) are not suitable with smo reflectors. Tint shift is too big for comfortable usage. The only cree multi-die led that is good with smo is mt-g2.
Reflector size too die area ratio is too small for any impressive throw, I think extra green areolas absense is more significant neither extra 10m of throw.
Aren’t you answering your own question?
You asked why they are not using OP reflectors then you say that OP reflectors are not suited to this light.
What???
