:+1: …. Your welcome, glad I coud help.
BTW, the SV2 is practically half price at illumn. I’m not sure if they are a sponsor here so I won’t post a link, but I’m sure most folks can find it just fine.
Got me 2 on the way!
That is a good price… you hit a homerun on that.
Would’ve sworn the question was about charging the 4 18650’s of the Q8 all at once at 1A…
I was kind of asking about that, but it’s been mentioned before that the Liitokala Lii-500 is a great choice. Simple and inexpensive. I was trying to make the question a bit harder looking for a similar power charger but holding 4 of the bigger 26650 cells.
Maybe in the future charger companies will realize they can increase sales, just by using a slightly larger housing to fit 4 big cells.
All 88 got it, they do 8 at a time, 1A to each, regardless of size (that is, if you select 1A, goes lower too and they do NiMH as well). I have 3 of em, if I can work em, anyone can!
All 88 got it, they do 8 at a time, 1A to each, regardless of size. I have 3 of em, if I can work em, anyone can!
I was looking at it and it does seem pretty complicated. One thing that made me pause was that the terminating voltage from the All 88 tended to vary from 4.14 volt to 4.19 volt (according to HKJ’s test). I don’t think it’s a big deal in the real world, but I wish it was a bit more consistent. Does it bother you any?
It would be a great choice for these guys who are buying 2 of the Q8’s. Charge all 8 cells at 1A at the same time.
Yes, that’s true… but it’s been pretty much true across the board from my experience. My Efest LUC chargers terminate early, my Opus C3100 V 2.2 terminates early, I’ve bought new chargers many time for this reason. When I modify a light I go to great lengths to reduce internal resistance everywhere I find it, I don’t do all that just to put a cell in it at 4.17V and see what it does with a short cell! Still, for those heading back out into the night these chargers are viable options.
For me, quoting the numerous builds I do, I want a consistent 4.20V on my cells.
If you want to charge 8 cells, all 18650’s that want 1A charge rate, you put them in, you adjust the first one to 4.2V and 1A, then you press and hold the two center buttons and all 8 cells snyc up and charge the same. Simple.
“All 88” = This …. for those of us who may be semi uninformed.
Review by HKJ
http://lygte-info.dk/review/Review%20Charger%20GyrFalcon%20All-88%20UK.html
That’s really not how BLF works. It’s just a weird policy on an unrelated for-profit forum. People don’t get banned here for that sort of thing. So feel free to post links to whatever, as long as it’s not spam or malware or something.
In any case, Illumn is good people and they’re respected on BLF.
GyrFalcon at Mountain Electronics, Richard of course is known and loved by us all!
All-80 at Mountain Electronics This one charges all 8 at 650mA and is cheaper.
He’s out of stock on each at the moment, but these are chargers he uses personally at his shop so you know they’re thoroughly vetted.
Meanwhile, I specifically seek out chargers which terminate a little early. My D2 stops at 4.18V and I think it’s just right. I’d much rather have a charger stop a little early instead of a little late. I don’t like gifting to others if I know it’s going to charge until 4.23V, because it’ll kill their batteries faster.
A little early cutoff is good for cells right. Though I don’t think the lii500 cuts it off early
Haha TK pix2pix is actually pretty impressive imho
Add one more for me thank you! (2 total)
I am number 1346 in the list.
MiBoxer is supposed to be having a new charger coming out, the C2-4000, that will do 4 x 26650 at 2A each charge rate.
It should also do 4 x 2A discharge rate & show capacity & IR on all 4 slots from what I have been led to believe.
They have just started a thread about it in the charger forum although the pictures do not show Miboxer new charger release C2 4000 & there is no spec listed as yet.
It might be worth looking at for those that want to charge 4 x 26650”s simultaneously & at 2A.
that thread shows a dual bay charger, the MiBoxer website has 1 quad bay but that does not seem to be able to take 4 x 26650
Yeah, I think the C2 means 2 cells, while the C4 has 4 cells.
I sold my VC4 recently because it charged to 4.22v. I have killed cells before charging them to 4.3v by mistake, only took once and they were all but useless after. So I now charge my cells a bit under, usually around 4.15v and don’t worry about it. There is so little energy available above 4.1V it really doesn’t matter unless you are chasing high numbers for those first few seconds.
I tend to quit using a charger that won’t put 4.22V in a good high discharge cell.
When I posted there were no pictures or details on that thread.
The C2-3000 was their latest charger, a 2 bay offering capable of 2 x 26650 at 1.5A per slot iirc.
Their next charger release was supposed to be a 4 slot, 4 x 26650, 2A charge & discharge, capacity & IR testing on all 4 slots.
I assumed that this latest charger the thread was about (prior to seeing any pics or specs) was this new 4 slot offering but it seems that it is an upgraded C2-3000, with user selectable charge rates as opposed to the automatically selected charge rates of the C2-3000 ?
They definitely do have a 4 slot, 4 x 26650, 2A per slot charger in the pipeline though as I have received several emails from them regarding it.
