Heck yeah… ask away. :+1: … If you have any good “off topic” chatter or info throw that in too. It has been pretty dead on the thread the last few days.
We gotta keep the post count up ya’ know……
Silence from ThorFire as of late. I'm getting ready to commit to the current NarsilM firmware release, so only other issue is the springs. Think the Chinese holiday delayed things. Also the ThorFire guy we deal has to translate and communicate with the engineering team at a remote location, so it can take a while for the back and forth. I'd speculate some of that is goin on. Plus I would think they woud be checking sourcing for springs, and the holiday made that difficult I'm sure.
Using an IMREN 16340 (from IMRBatteries), got 5.5A at the tail (clamp meter), 1,460 lumens @start and just 24.6 uA parasitic drain (224 uA w/switch LED on).
All running NarsilM w/smooth ramping and all the features the Q8 has: temperature step down, switch indicator LED, lockout, LVP, blink out voltage and temp, blink at a ramping level to show output channel your running on, blinks: 1: 7135, 2: bank of 7135's, 3; FET), plus all the mode sets and configuration settings the Q8 has
Hey, that’s my EDC light. Did you piggyback a second driver board in there? I can’t tell as I’ve never had mine apart. This sounds like a great mod. If you go into more details on another thread, please post a link here so we can check it out.
Hey Tom, I’m curious - how does the temperature stepdown work? Do you have a thermistor on one of the pins, or is there a relationship between the temperature and the current into the LED that you can measure from there?
The ATtiny25/45/85 have a built in thermistor, so I'm using that. It's notoriously off calibration from MCU to MCU. This one in the M3 reads bout 20-22C high. I'm using -19C as the calibration offset.
The driver has to be sanded down, trimmed, shaped to fit - it was nasty, but works. Someone like DEL could probably design one to match perfect to the stock, then buy them at OSHPark. That would be better all around - easier and better thermally.
Yea, that's what I thought, but those are clear - I got a bunch of those already. Didn't try them but they could be the same size, as described. Both say 8.4 mm - think this is the typical small XML size hole.
And something more offtopic.
I will order a few UV LEDs in the next days. And i will have some left to sell (Non profit). I asked djozz and from the pictures it is a LG 3 Gen UV LED.
Further information in this Thread: Cheap bare 385nm UV LED
It sure does!!! :+1:
But I think you could mount a Q8 right on top of the air dam with a special made bracket. For those time when a bit more light was needed.
I can’t speak for lionheart but yep, mine was a semi “on topic” joke.
But yep, what you said about light bars is right on target TK. I don’t have a RMM model yet, but I’ve had some for a while now. And nothing beats them as far as I am concerned…. especially out in the boonies where you don’t have to be concerned about blinding oncoming drivers.
I hope to try a RMM version in the future.
Good led headlights are hard to find. They are usually not the right size and shape to match the original filaments. I’ve also never seen 5500k, they are all usually 6000k to 7000k. A lot use fans which will fail. I had a great set in my car, but after a year the Luxeon chips are starting to fail. So now I’m back doing research on the new 2017 model lights. The first replacement set I bought last week had different leds than what was shown and they had 1/4 the output to my old ones. Back they went. I ordered 2 other sets and will be trying them out.
