I donāt know if this is what you mean, but in the Narsil reference manual, in the advanced configuration section at the end of the manual, one has the option of disabling the button LED.
Hank, I donāt have a huge amount of experience with lights, but the Narsil programming is pretty fantastic. It gives the user the most control of any light that Iāve ever seen. Most programs for lights give far less control or no control at all.
I think youāll be happy with what you can do with the UI.
can do a lockout, and when it's locked out, the Ind. is OFF - I thought that made the most sense for most common usage (4X clicks in ramping to lockout, other way in mode sets)
can also use a quick shortcut to disable the Ind. LED when the light is OFF, in both ramping and mode set operation (ramping: press&hold til the light goes on in moon, quickly release)
can also disable it completely in the configuration settings
I knew this would be a wanted feature so put in a lot of support for it.
Tom E posted the below back in #7351. His numbers are a bit different from what DEL found, but there is certainly little danger of parasitic drain rendering the light useless in time of needā¦. even if the user is just halfway paying attention to their light every few years. ā¦
I just spent 350 dollars online, and not a dime of those was for the Q8 will have to resort to throwing wads of cash at my computer screen to get things going.
I am so glad you guys are on top of things and have caught/noticed/seen this delamination issue so that it can be addressed & corrected before production.
Depending on how bad & widespread it isā¦. this was a potential Q8 disaster in the making. :person_facepalming:
Hatās off to you all for being on top of things. :+1:
I guess thatās why multiple protoās where asked forā¦ If itās a proto board then the issue could be resolved easy. If not it might be a good idea that the team looks for a mpcb producer? Although I donāt think I ever heard of thorfire lights having this issue or they never designed a light pulling 20A in stock form.
