BLF style 18650 1s thrower( poor mans Olight M2X)
It all depends Mitkoā€¦ For someone without lathe or without possibility to hand file or rasp the pill to fitt 26mm mcpcb that method could be harderā€¦
BTW does newer breeds also draw 3,6A of current like first batch of new ones? I know that first batch of new xpg2s42b draws only 3,6A of current on fet driver.
And of course it canā€™t be better than old one. New one wonā€™t reach 321 kcdā€¦ No chance for thatā€¦ But it will give longer runtimes on turbo. This is single 18650 light after all?
But how do you install the manker mcpcb? Wouldnt it leave a hole under it where normalu the 16mm mcpcb sits?
Hi, New XHP50.2 dedomed, could it be an option? Bin is not equal to xm-l2? Greetings.
Do you mean those with the bigger die but the lower Vf (draws 4.3 - 4.7 amps) ?
Btw , my first supwilfire was great , had the nice black centering ring Mitko mentioned and reflector was super clean , my second one is really disappointing ! Glass has some marks that canā€™t be cleaned , reflector is full of dirt and centering ring is the unusable one .
I had good results with this centering ring
Friend you did not read a single thing from this thread? :smiley: Thatā€™s OKā€¦
You must add thin copper plate into that hole (up to 19mm wide and up to 1,5-3mm thickness) than you must use lathe to take pill top and to make it flat to that copper plate and sand and polish everything up.
Or if you donā€™t have lathe or mill you can file or rasp it to that plate by hand but you must be very skillful for this (gunsmith skills)
So Junior librarian job (click and youā€™ll see)
I have another Supwildfire waiting, and a 26mm Maxtoch board. I will clamp the pill into a vice and use a hacksaw to saw the rin off the pill, and then file and sand it flat. No lathe needed. Will make a few pictures when I do that.
In mine used only a big file and sandpaper , didnā€™t take much time . My current one will be done with the hole in the reflector , since i donā€™t have any 26/28mm boards for now ā€¦
Lathe is most accurate method. Hacksaw? That is braveā€¦ Very thin hacksaw blade could do it I guessā€¦
I see you got one with dirty reflector and lens. Use my above mentioned method for cleaning that out. It should work.
I did read it :nerd_face: i think i got things mixed up because not everyone is using the same methodā€¦ and i dont have a lathe but maybe with a file and a whetstone :partying_face:
Tried cleaning glass but it wonā€™t clean .
Not touching reflector with something , lesson learned :disappointed: Even microfiber cloth leaves micro scratches
[quote=giorgoskok]
I disagree. Some guys are cleaning camera sensors and lenses with same stuff(you can use very fine microfiber cloth if you are concerned) and I donā€™t even have to tell how sensitive stuff is that.
But I respect your opinion. I guess even dirty reflector will throw. Reflector from Supfire factory really comes fingerprinted and dirty from factory. They use slap and play assembling method.
I could not resist anymore so i ordered one to test this thing out, my plan is fet driven xml-2 on maxtooch board, i have no use for that led-board combo so i thought i give a chance to this light, it should be fun modding it :smiley:
I just need to find cheap cooper board so i can make spacer from it, those noctigon boards that i have all around me are too good to chop them.
Jay, I had time for a mod today!
My second Supwildfire. It had the fake XM-L2 and a cheap aluminium pill. But also a fat Omten switch at the back which is nice, I only had to solder a wire from the brass cap to the bottom of the spring, add a colourful silicon tailcap and the tail was done.
So I had bought one of those expensive 26mm Maxtoch boards (before I knew about the cheaper Manker version ) and all was fine they said. Well, I do not know how other people did it but for me it required quite some fancy pill modifications to get it working.
Sawing off the rim
Sanding the top flat (a very thin edge was leftover, later I removed it)
Holes drilled in the side
Dremeled the opening out. Also added 20AWG wires to a bistro-driver and made a spring-bypass. Also carefully reamed the reflector opening so that one of my better centerpieces would exactly fit. The centerpiece was also sanded down on the underside so that it only sticks out of the reflector by just a fraction of a mm (=correct focus for a dedomed led!)
Then flattened the Maxtoch board on the underside as well as possible (800 grit) reflowed an old type XP-G2 S3 3D on it and hot-dedomed the led (went well :-) )
Then the driver was fixed into the pill (it has a well working retaining ring for it :-) ), applied a very thin layer of Arctic silver 5 on the pill, screwed the pill into the head into position (top level of the pill just above the shelf in the head surrounding it) and fixed the position by screwing in the battery tube against it (very tight). The ledboard was pressed on the pill and the ledwires soldered. I did not fix the board to the pill, just hoped that when screwing down the bezel, the reflector would not shear something off.
It worked well, the reflector nicely pressed down the board when closing the bezel, without damaging the ledwires (at least the light works fine )
Now I have two of these modded!
The current on a VTC6, measured with a clamp meter with the tail section of the flashlight off, is about 3.9 A. The output at 30 seconds: I measured 965 djozz-lumen. I carefully measured the throw (VTC6, 30 seconds, 7 meter distance) and measured a rewarding 322 kcd. And very steady as well, hardly dropping output, perhaps thanks to that huge Maxtoch board.
Good job !!!, what centering used for xpg2? regards!!
I used these from Banggood: 5 StĆ¼ck Konvoi XPL Isolationsblatt fĆ¼r 9-mm-Reflektorloch Sale - Banggood Deutschland sold out-arrival notice-arrival notice , they are too large so I reamed the hole in the reflector to exactly fit the center piece.
Very nice mod djozz :beer:
That beam tint looks like my old maglite magcharger :slight_smile:
Nice modd Djozz but no freaking chance that old XP-G2 S3 3D throws same or better than mine good old XP-G2 S4 2B. I would bet with anyone any day for that statement.
Since you are so far away I guess I will have to send mine Mitkoā€™s thrower to you for proper measuring. Cause that cheapo we both have even with your mentioned 11,4% add on measurement gives same numbers as yours on fully charged Samsung inr 30Q.
And BTW all my pictures disappeared from forum. Fā€¦ā€¦g Photobucket!
Sorry about your pictures, Iā€™m lucky to always have used flickr, until of course they will start charging as well :frowning:
About the mod doing the same numbers as your S4 2B: I did do everything very right, including the focus :innocent: :partying_face:
