Can do 3V LEDs like the SST-90, just not generally recommended since that much current will blow almost any modern 3V Cree LED sky high. Although an XP-L or XM-L2 at 5.5A will put out more light than an SST-90 at 7A....
Sorry guys, haven't been on here much lately. Things have been crazy busy around here---I feel like I've been pulling double or maybe even triple duty.
A few updates:
Aspire 18350s have been ordered and hopefully will arrive soon.
DrJones guppy3drv has been released for all FET+7135 drivers.
Thermal throttling.
Lots of mode groups, but less clicking.
I finally got some time to sit down and work on some new driver designs and updates. The next to be released will most likely be the 17mm boost drivers. Thermally it is not an easy task due to the limited space...still not sure if I can get the full 10A input and keep reliability. Time will tell.
The new D4 tiny 18650 quad from Int'l Outdoors is pretty sweet. I've had a review light and have been using it nonstop for a few days now. It was sent to Tom E. for a full review, but I can tell you that it is going to be a heck of a deal at around $35. It is obviously thermally even more limited than our typical triples...but the size and weight more than make up for it if you're looking for something pocketable without giving up 18650 capacity.
Sweet! I'm glad that it was worth the extra effort to offset the LEDs...putting them square is much easier! Making a 1S parallel board also would have been much easier, but I know that there are still a lot of guys who use these in 2S2P and 4S. Also would have been easier if I didn't make that center hole so big...or the wire pads so far away from the LEDs....you get the picture. No design is perfect, but I knew that I would have to live with reflowing and using hundreds of them myself, so I tried to make a design that I could be happy with even if it took me a few iterations to get there.
Oooh ok thanks for the clarification!
The 3v LED I’m planning to use will be able to handle 7A, it will have some extreme cooling (not the SST90 btw)
I’ll be buying one when you get it in stock.
Yes, of course we will be stocking the D4. We have already ordered some.
The beam will be like the TPAD since the LEDs are in the same configuration. I recommend not going with the XP-L HI in this light for that reason alone. The 219Cs look good, XP-G2 acceptable, but XP-L HI were always very square in that quad configuration.
Seems very interesting. Could you tell us more? Is it related (either technically or inspirationally) to GXB17? What variants are you planning? 6V? 8V? 12V?
Is there any timing info that you can share?
This has me wondering what would be the quickest way to get one. US Shipping takes a lot longer from Hank, but he will probably have them available sooner unless you have a simultaneous-release thing set up.
I am not sure which way will be the fastest, but at the end of the day you have to ask yourself who you want your money to go to. Who will give you better and faster support if things go wrong? At the end of the day, I hope that's mostly what we provide, because the Chinese sellers can sell things cheaper than we ever could---they have a huge labor, shipping, and tax advantage, so if we want to stay relevant it had better be for reasons other than price, even though we do still try and be competitive there as well.
